Where is everyone grounding their amp??
Old Mar 23, 2004 | 09:07 PM
USMC-Z's Avatar
USMC-Z
Z Veteran
Default Where is everyone grounding their amp??
I cant find a single place around the passenger back seat to ground my amp. Does anyone have any suggestions?
Old Mar 24, 2004 | 12:13 AM
jreiter's Avatar
jreiter
I can't really give you any specific sopts, but hopefully I can give some general info that might help. Everyone probably uses different spots for grounding, depending on how they did their particular install and amp placement. In general, you want your ground wire to be as short as possible and have a good connection with a large body of metal. (Not a small chunk of metal, but something like the inner body skin just beneath the plastic panels.)
I've found that there are tons of little holes and things all over the metal of the interior skin once you take off the plastic panels. Just utilize one of those if you can find one. You'll probably need to get a custom screw of some sort and forcefully thread the thing into the hole to make sure it sticks tight. And for good measure, it's usually best to file away the paint around the hole so your ground gets a good connection. Heck, if nothing else, you can drill your own hole through the metal. Just be sure not to drill into something critical like the gas tank!
Old Mar 24, 2004 | 05:19 AM
SmO69's Avatar
SmO69
There's screw holes all over the floor of the trunk when you remove the carpets. Just find a screw that fits.
m_0g
Jun 3, 2021 10:05 AM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
