Wiring the basslink with RCA cables... HELP?
Old Jun 17, 2004 | 10:54 AM
Conceyted's Avatar
Conceyted
Default Wiring the basslink with RCA cables... HELP?
Well, I see the basslink has Front and Rear connections for rca inputs. I had no clue which to use, so i just put them both in the front part (not paying attention to the manual) Well Syf3n has the same setup as me, basically. And i noticed the guy who did his used rca splitters (Y splitters) and connected his rca cable to the front and rear sections. What do you guys think would be best? I will have pictures up in 5 minutes showing each possibly wiring config.
Old Jun 17, 2004 | 11:05 AM
Conceyted's Avatar
Conceyted
heres the cables
Conceyted's Avatar
Conceyted
how it works
Old Jun 17, 2004 | 11:11 AM
Conceyted's Avatar
Conceyted
config 1
I color coded the wires to match pink for red rca and blue for black rca
Old Jun 17, 2004 | 11:12 AM
Conceyted's Avatar
Conceyted
Config 2
Old Jun 17, 2004 | 11:13 AM
Conceyted's Avatar
Conceyted
Config 3 (my original config and not as strong bass)
Old Jun 17, 2004 | 04:07 PM
Conceyted's Avatar
Conceyted
bump... help if you can guys!
Old Jun 17, 2004 | 09:35 PM
ad350's Avatar
ad350
Does your HU only have one rca output? I put both the front and rear outputs from the HU to the basslink. The Y spitter really doesn't do much if the HU is only putting out half the bass.
Old Jun 18, 2004 | 05:25 AM
Conceyted's Avatar
Conceyted
well, my alpine headunit has a subwoofer rca output and 2 other rca outputs. I do not think these are front and rear though, if that was the case you wouldnt be abel to put any other amp to your speakers, the basslink would take up the whole set of outputs, right?
Old Jun 18, 2004 | 05:56 PM
jikman01's Avatar
jikman01
I just did like the Basslink instructions said and used my Alpine SUB RCA output directly to the low level inputs for the FRONT only. The bass is good. I never tried what you are saying. I would not want to use my front and rear RCA outs for the basslink because then you can't use any additional amps like you said.
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
