Delphi SkyFi XM radio installed
Old Jul 12, 2004 | 02:05 PM
bradg's Avatar
bradg
Default Delphi SkyFi XM radio installed
Just thought someone out there might want to see. I used a dremel tool to cut out a section of the nav compartment to hide the cradle and allow the Delphi SkyFi to fit in the nav compartment. I like it much better than where I used to have it mounted (by the passenger's left knee).
Old Jul 13, 2004 | 06:19 AM
only1's Avatar
only1
Do you have to hav a head unit the is satelite compatible? I have an after market HU, but it doesn't say anything about satelite radio. It is a JVC. Am I able to set it up still with this HU or am I stuck buying a new one?
Old Jul 13, 2004 | 01:19 PM
bradg's Avatar
bradg
no, you dont need a specific headunit, just one with auxillary inputs. The Alpine 9831 I have has an adapter that allows RCAs to be input. The actual output of the XM radio is just a standard headphone jack. If you dont have a way to input signals, then they sell a FM modulator. It is directly wired to the antenna line just behind the headunit, and has like three selectable frequencies. I was using it with the stock headunit and had very good results.
Rowlett
Misc.
Oct 2, 2015 10:38 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
