Just finished part one (pics)
Old Jul 17, 2004 | 10:02 PM
orgasm_donor's Avatar
orgasm_donor
Default Just finished part one (pics)
Not my car but I'll show you guys anyways.
Integrated BOSE system with new Alpine CDA-9833 (For now!) via Metra adaptor:
Took out the tray inside the glovey and installed lower amp rack for MRD-M500 amp:
Blurry pic of said amp:
Amp shelf for future 4-channel amp MRV-F340
1.2 cu.ft. box for two Type R 10's with first panel to be vinyled in black:
Finished product with vinyl and carpet:
Close-up:
The factory sub was removed dude to cancellation problems. This set-up pounds pretty darn good and actually sounds quite nice for Type R's. The new amp will be installed sometime next month when my buddy decides on his components. I'm pushing him for a set of Boston Pro65's
Mike
Old Jul 17, 2004 | 10:51 PM
Reggi914's Avatar
Reggi914
nice, you still have some trunk space
Old Jul 18, 2004 | 06:44 AM
maxipad96's Avatar
maxipad96
Why didn't you put the amp/amps in the stock sub area? You are losing some space in the glove box. Looks good though!
Old Jul 18, 2004 | 07:21 AM
roydiculous's Avatar
roydiculous
Is your sub enclosure permanent? I mean can you remove it? Do you have a pic of it removed? I'm looking to do the same exact setup. I want something that passerbyers can't see.
Old Jul 18, 2004 | 04:54 PM
orgasm_donor
This system is semi-permanent BUT not one hole was cut or drilled at the guy's request. The sub box is not bolted down but rather the panels are installed in such a way that everything is sandwiched in there making removal difficult at best.
Putting the amps behing the driver would have been ideal but it would have involved modifying/cutting the metal subwoofer baffle which was out of the question. Instead, he uses this 'hole' as a large storage bin.
Mike
Old Jul 18, 2004 | 05:09 PM
350ZOWNZ's Avatar
350ZOWNZ
the thing the subwoofer bolts on to unscrews u know... u have to take the paneling off tho to get to the screws.... I put my amp there. perfect spot imo
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
