Alpine?
Old Jul 25, 2004 | 01:56 PM
McBickBick's Avatar
McBickBick
Default Alpine?
กกก Hi all !!!
I just got my Z and I'm already thinking about changing the stock audio system, but this is my first time changing the audio system so I've got some (newbie) questions. I thought about Alpine products, I think it's a good company, but how i've said before, it's my first time and I'm not sure about using Alpine's products. Any good/bad aspects about Alpine? if, finally, I choose Alpine, I've seen the MRD-M1001 Amp, but I don't want to fill my trunk with all the audio system, I want to use it as what it is, but this is a huge amp, and one I think is enough filled space in the trunk. Is any posibility to connect two subs this one mono amp? the subs I thought are the new X-series SWX-1242D or the R-series SWR-1241D.
Any good/bad aspects about this subs?
Thanks
Old Jul 25, 2004 | 02:45 PM
Z_Coaster's Avatar
Z_Coaster
I have a Alpine HU with an Alpine amp pushing the front and rears. I prefer Alpine HUs. I don't care too much for Alpine subs.
I recommend JL Audio amps and subs. I have a JL audio 500/1 (it is a mono amp) pushing 2 12" JL subs (12w3). The 500/1 is just barely keeping up. If you don't require too much out of your subs, the 500/1 is a good amp to push two 12s.
Couple of things to keep in mind.
Go to a local audio shop and listen for yourself. Everyone has their own opinion/preference. The shop should also help you with maintaining the correct ohm configs.
Sub location and the box are both very important to the quality of sound.
Old Jul 25, 2004 | 06:53 PM
mofoz's Avatar
mofoz
Alpine Head Units simply rock. Unless you want a LCD screen, go with Alpine. Their CDA line rocks, and the display on hte 9835 is awesome. I choose a JL Audio 10w6v2 which is 400watts at 4ohms matched with a phoenix gold 400x1 at 4ohms and it simply pounds, yet is still tight and responsive. The phoenix gold can sit under the hidden floor in the glove box, and i fit a 300x4 JL Audio amp in the glove box, and mounted the sub behind the drivers seat for a completely stealth look(by using the stock bose sub panel) I couldnt be happier.
dcains
Nov 11, 2015 11:36 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
Nazar
May 26, 2003 09:37 PM
toothlessracer
Mar 15, 2003 09:06 AM
dmcgibbo
Nov 30, 2002 10:11 AM
