Alpine MRP-M350 question
Old Aug 27, 2004 | 01:21 AM
tractng's Avatar
tractng
Default Alpine MRP-M350 question
Guys,
What does this mean? Do I have to get two subs to achieve 350 watts (RMS)? I am planning to just get one Infinity Perfect 10.1d.
http://www.crutchfield.com/S-UWhGZ43...search=car+amp
Here is the spec verbage: Hook up the MRP-M350 to one 4-ohm sub, and you get 200 watts RMS; connect a second 4-ohm subwoofer and the power output increases to 350 watts! All that juice means that your subs won't just be loud, they'll sound clean and musical, too. A variable low-pass crossover lets you tune the output to match your particular sub setup.
More spec
200 watts RMS x 1 at 4 ohms 350 watts RMS x 1 at 2 ohms requires 8-gauge power and ground leads — wiring and hardware not included with amplifier MOSFET power supply
Tony
Old Aug 27, 2004 | 10:56 PM
350zWannabee's Avatar
350zWannabee
the infinity perfect sub is a dvc (dual voice coil) @ 4 ohms i believe, you would get 350 watts out of that amp as long as you hook up the dvc in parrallell
ps: make sure its a dvc, think of a dvc as 2 sub woofer hook ups
Old Aug 28, 2004 | 12:47 AM
tractng's Avatar
tractng
350zWannabee,
So you are saying I could use one sub to achieve 350watts (rms)?
Yes, this is a dual sub.
Tony
issyz
Jul 2, 2017 03:04 PM
dcains
Nov 11, 2015 11:36 PM
Alexreyes
Sep 30, 2015 11:30 PM
