Which amp?
Old Aug 30, 2004 | 08:24 PM
tractng's Avatar
tractng
Default Which amp?
Guys,
I just purchased an Infinity Perfect 10.1d sub. I need amp to power my one sub.
Which one is a better choice? Which one is more stable at 2ohm?
note: I might stay with the stock HU for now.
http://www.crutchfield.com/S-cMw5e4P...search=car+amp
Thanks,
Tony
Old Aug 30, 2004 | 10:17 PM
stu46's Avatar
stu46
i'm a firm believer in you get what you pay for. i own a PG amp, it's very solid. rated at 300 rms, puts out 340 rms. i would spend the few $ extra for the PG. plus it's better looking. check out their tantrum line also. i've got the PG tantrum 300.1.
Old Aug 31, 2004 | 07:02 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I like the Alpine amp personally. I have a MRV-F450 powering the whole car. never gets hot..
I also have a Phoenix Gold XS 2300 amp, it gets very hot.. so, it all depends..
Old Aug 31, 2004 | 08:28 AM
vanwinkl's Avatar
vanwinkl
I also have the MRV-f450 Alpine. It is a great amp and it slots in nicely into the compartment behind the passenger seat.
Old Aug 31, 2004 | 10:51 AM
tractng's Avatar
tractng
Guys,
If I get the MRV-f450, would I be still be able to use my sub (Perfect 10.1d- which is a 4ohm dual voice) wired as 4ohm?
What sub are you powering with the MRV-f450?
Tony
Old Aug 31, 2004 | 12:59 PM
vanwinkl's Avatar
vanwinkl
Infinity Kappa Perfect 10VQ 10" subwoofer
Old Aug 31, 2004 | 03:56 PM
Vivid Racing's Avatar
Vivid Racing
Vivid Racing
If it is a dual 4 ohm it can only be set up as 8 ohm or 2 ohm. Go with the Phoenix Gold but you can get it cheaper here. http://www.onlinecarstereo.com/CarAu...roductID=12981
Old Sep 3, 2004 | 10:32 PM
tractng's Avatar
tractng
Guys,
I just got the phoenix gold amp R5.0:1.
Here is the link:
http://www.crutchfield.com/S-xIFsPNB...search=car+amp
My question is there are two sets of terminal speakers + -- + --.
On the manual it has a side note of: The seperate + and - terminals are internally wired in parallel.
How does this affect my wiring of one sub (Infinity Perfect 10.1d), which is dual coils? I haven't received my sub yet.
Here is a picture from JL, would I just still apply to picture one? Use the positives from the amp and connect on each side of the sub (same as the negatives)?
Thanks,
Tony
tractng
Old Sep 4, 2004 | 04:21 PM
bastard's Avatar
bastard
It has two outputs so you can hook up two subs. If they are wired in parallel, it would be the same (to the amp) if you wired each voice coil separately (the third picture) as if you wired them in parallel (the first one).
I would suggest you just wire the sub parallel (first picture) inside of the box and run one speaker wire (not two pair. just one). Saves you a couple bucks and results in fewer wires to hide, and has the side benefit of only requiring a 2 post terminal instead of a 4 post (matters only if you build your own box)
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
Shane86
Sep 17, 2015 05:33 PM
