Removing dash to install HU
Guys,
Its a last minute thing. I used to bookmark it, but cannot find it. Any links to show me how to remove the dashboard to install my HU.
I am leaving work soon.
Thanks,
Tony
Thanks,
Tony
I just did this tonight. You need to move the shifter trim out of the way, you can remove the shifter and the entire panel, but I didn't. Then remove the two screws in the navagation/ storage compartment. They're under the panel on the front lip. Next remove the two screws on the upper portion of the deck(they are back there a ways). Then remove the screws on the bottom half that were exposed when you moved the shifter trim. There are two on the outside(very easy to see) and two further in that connect the heater controls. Pop off the panel and disconnect the wire connected to the mileage/MPH/Avg MPG...etc. The entire dash panel will come off. You'll need to remove the four screws holding the deck to the bezel. From there it's the infamous "reverse of removal". Good Luck, and take your time. Not worth scratching and of the most seen pieces in your whip.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
