Sub Woofer Questions
Old Sep 22, 2004 | 11:20 PM
mbonanni1856's Avatar
mbonanni1856
Default Sub Woofer Questions
So I put a 10" in the factory hole behind the drivers seat and it would not stop rattling. I knew it wasn't the best setup to begin with, but I had an extra 10" lying around so I figured what the hell...anyways I took it back out because it was unbearable. I am going to do a custom installation, but without doing research I ordered an Audiobahn 12" and Audiobahn amp. I cannot figure out a good place to put the sub and amp where it could be displayed for car shows. I looked around on the forums and all I see are 10" Subs in the Z. Does anybody have a good looking 12" setup? If not I will just go with 2 10" and a custom box.
Old Sep 23, 2004 | 02:21 AM
stu46's Avatar
stu46
for car shows, more is always better.
lose the spare, build a sub-floor box.
Old Sep 23, 2004 | 09:21 AM
mbonanni1856
Yeah but then where am I going to put the amp. The size of the box needed takes up that entire spare tire well.
Old Sep 23, 2004 | 09:32 AM
stu46's Avatar
stu46
put it anywhere you want. in the glove, the trunk. it's up to you. go down to a stereo shop and talk to some of the guys. they can take measurements and make recommendations. you can also search this site to see what other people have done.
Old Sep 23, 2004 | 09:58 AM
mbonanni1856
Yeah I will probably end up doing that, and I have researched what other people have done, I am just trying to find a way to make the amp and sub visible.
Old Sep 23, 2004 | 10:00 AM
stu46's Avatar
stu46
lose the spare and built a sub-floor box. plexi for a window and you're done.
Old Sep 23, 2004 | 10:07 AM
mbonanni1856
Yeah I have gone through the measurements though and all that would fit down there is the sub box. I still have nowhere to put the amp.
Old Sep 23, 2004 | 10:14 AM
stu46's Avatar
stu46
a single 12" sub and amp will easily fit. there's about 2 cuft of space. i have 3 10w6v2 and 5 amps on display in the trunk.
Old Sep 23, 2004 | 10:18 AM
mbonanni1856
Do you have any pics? The Audiobahn web site said that for my box to be 6.5" tall it would have to be 22"x28" to get the right cu.ft. Did you take the styrofoam on the sides out?
Old Sep 23, 2004 | 10:23 AM
stu46's Avatar
stu46
everything comes out. foam, tire and all.
Old Sep 23, 2004 | 10:29 AM
dannichols's Avatar
dannichols
Now I see why you know so much about the rattles Stu. Did you help design and build that enclosure?
Old Sep 23, 2004 | 10:56 AM
stu46's Avatar
stu46
a combined effort between the shop owner and myself. more if his idea though. i picked out the equip. i knew i wanted 3 subs for the more symetrical look. IMO, 2 subs doesn't look as good as 3. i also wanted to display the amps around the subs. so he designed the amp rack. so, pretty much told him what i wanted and he came up with the design. that's an old pic. now i've got some reflective plexi in there.
Old Sep 23, 2004 | 11:28 AM
mbonanni1856
Man, that is a SWEET setup. Good job. Thanks for the advise. I will recalculate it with the styrofoam out.
Old Sep 23, 2004 | 12:19 PM
Zrated's Avatar
Zrated
Thats INSANE! How many times have you had to replace your rear window?
Old Sep 23, 2004 | 08:57 PM
rotaryrocket7's Avatar
rotaryrocket7
I built a tiered box that fits competely under the stock carpet. I'm in the process of putting a cover of them with removeable windows (plexi) I have 2 PPI Pro 12's and two PPI amps. Box is about 2.3 CF ad made of mostly 1/2 HDF. (Top is 3/4 with 1/4 inch built inside the box for flush mounting) When everything is finished I will post pics. This is my fifth night after work building and installing everything, the end is finally near.
Old Sep 23, 2004 | 09:45 PM
mbonanni1856
rotaryrocket7 - Yeah I would love to see those pics.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
