Rear end rattle
Old Sep 23, 2004 | 07:39 AM
dannichols's Avatar
dannichols
Default Rear end rattle
Besides Dynamating the floorpan area (did that) does anyone have other suggestions for limiting hatch area rattles from bass?
Old Sep 23, 2004 | 09:20 AM
stu46's Avatar
stu46
Default Re: Rear end rattle
remove the shade for the brake light. i also disconnected the brake light.
Old Sep 23, 2004 | 09:42 AM
dannichols's Avatar
dannichols
Great thanks for that. I had taken off the upper molding to remove the wiper and motor and did put some sound deadening up there but only near the lower section.
There are two metal brackets under the rear lower plastic panel, do these casuse a rattle problem? And lastly in the rear corners are those two baffle like air vents that allow the hatch to close without much force, these seem to cause rattle for me too.
Old Sep 23, 2004 | 09:46 AM
stu46's Avatar
stu46
once i removed the plastic shade, no rattles.
Old Sep 23, 2004 | 09:48 AM
dannichols's Avatar
dannichols
Really? that was the major cause?
dam, I think I just wasted 25 pounds of Dynamat ;-)
Old Sep 23, 2004 | 10:21 AM
stu46's Avatar
stu46
dynamat the trunk is a good thing. there's a lot of road noise that comes through. i did that also. but for the rattles, the shade was 90% of the sound. also, the sunglass holder. that sucks. i got some felt stickers and put them in there.
Old Sep 23, 2004 | 10:24 AM
dannichols's Avatar
dannichols
OK, now that brings me to another question. I used Dynamat on basically the entire lower portion of the car, and I agree that it is a great sound deadener for road and tire noise and it does limit rattles in those areas too. But it is expensive and thick and a pain to cut to the right shape and apply.
So there are areas like the panels around the strut bar and the sunglass holder, and other small plasticy spots where dynamat just doesn't work well. What do you suggest as a light material to limit rattles in those spots? Dynamat seems like overkill there.
Old Sep 23, 2004 | 10:29 AM
stu46's Avatar
stu46
other than the shade and sunglass holder, no other major rattles. i just turn up the stereo and they all go away. =)
Old Sep 23, 2004 | 10:34 AM
dannichols's Avatar
dannichols
Yeah mine go away if I turn it up too.. Well actually I'm sure they are still there I just don't hear it :-)))
Old Sep 24, 2004 | 06:57 AM
dinoz's Avatar
dinoz
What I do is avoid installing ridiculously large base speakers in my car.
Old Sep 24, 2004 | 07:05 AM
dannichols's Avatar
dannichols
How large is rediculous? I'm thinking of installing a 25" woofer in the trunk so I can use bass power to just bounce down the highway instead of using the engine. This will save gas.
Old Sep 24, 2004 | 07:11 PM
stu46's Avatar
stu46
wuss, gotta have at least 2. have it downfire for a little more hop. maybe ported with the ports facing the rear so you can get a little more distance also.
hulkout
Apr 28, 2017 09:00 PM
pr_350z
Oct 1, 2015 05:03 PM
