Do I need anything else to do the installation?
Old Oct 5, 2004 | 01:51 PM
MY350Z.COM's Avatar
Default Do I need anything else to do the installation?
Headunit
Amp
Components
Speaker Wire
Power Wire
Ground Wire
Interconnects
Fuse Holder
Fuse
Remote Turn on Wire
Ring Terminals
Battery Terminal
Tie wrap
Anything else?
Thanks,
Victor
Old Oct 5, 2004 | 02:03 PM
hndumafia's Avatar
hndumafia
if you are running multiple amps you will need a way to distribute the power. you can either run multiple power wires, in which case you will need multiple fuses and holders. another option will be to get a distribution block. third option is to get a cap and you can distribute the power off that.
Old Oct 5, 2004 | 02:11 PM
MY350Z.COM's Avatar
only 1 amp, for now
Old Oct 5, 2004 | 03:09 PM
rotaryrocket7's Avatar
rotaryrocket7
Probably want to mount amp to something other than the car (I didn't want to drill holes in my new car). A piece of wood and some expandable foam works great for cubbies behind seats.
Old Oct 6, 2004 | 07:33 AM
Zrated's Avatar
Zrated
You may want to use an accessory relay. I wired one using the amp turn on lead from the HU as the switch and tapped off my distribution block for power (I put a 15A fuse in line). So all accessories come off a barrier strip that is powered up when the HU is turned on. From this U can power Amps, Fans, lights, DVD player, Screen….all with no worries. If you want a pic, PM me with an email that I can send it to.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
