Sealed box
Old Oct 31, 2004 | 02:46 PM
tractng's Avatar
tractng
Default Sealed box
Guys,
I have asked this question before but never got a definte answer. When the manufacturer suggest the sealed box size, does that exclude the woofer?
Reason is that i want to build a box that fit nicely into the stock location.
Tony
Old Oct 31, 2004 | 03:29 PM
EnthuZiast's Avatar
EnthuZiast
Guess whose back, back again...
And I thought this was another thread about chastity belts !
Old Oct 31, 2004 | 04:31 PM
xxlbeerZ's Avatar
xxlbeerZ
The airspace required is what you have left when you subtract volume of the sub from the total airspace of the enclosure.
Old Oct 31, 2004 | 04:56 PM
GQ 350z's Avatar
GQ 350z
Tony,
I wouldn't worry too much, because in most cases subwoofer volume is negligible--like .16 cu ft, etc. For sealed applications just go as close to the manufacturer specs and call it a day.
Best of luck!
Ravi
Old Oct 31, 2004 | 05:51 PM
gundam02's Avatar
gundam02
JL audio does calculation of what the box would be with the Sub in it.
So basically if they recommend 0.5-1.0 and you have 0.5 before you put the sub in then you won't have enough.
But never fear, polyfill is here!!!!!
Old Oct 31, 2004 | 07:08 PM
tractng's Avatar
tractng
gundam02,
You mean with most other brands regarding this quote, but not JL.
Btw, I love your box. I want something like yours, but i am just too afraid of breakin.
What is your opinion of a JL 10w6v2 in a stock location? I meaured today and it looks like i can fit a seal box in there with this sub in it. It will fire upward. I will use mostly use mdf except for the base (fiberglass) to save some room.
Right now i have an infinity perfect 10.1d sub in a sealed box in there. Just want a little more punch.
Tony
Old Nov 1, 2004 | 10:33 AM
JimRHIT's Avatar
JimRHIT
Guys ... do not ignore the volume of the subwoofer. Think about it. A 1.0 ft^3 enclosure is now made into a 0.85 ft^3 enclosure with the driver displacement. Polyfill is not a band-aid to make up for lost space, rather it should be used to tame the box in the end.
download some simulators, input your parameters and try a 0.85 and 1.0 ft^3 box .... see the differences ... they are not negligible.
Jim - your local transducer engineer
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
