Can aftermarket screen work with stock DVD-drive?
Old Nov 4, 2004 | 12:47 PM
acerys's Avatar
acerys
Default Can aftermarket screen work with stock DVD-drive?
Old Nov 4, 2004 | 03:32 PM
jeffa's Avatar
jeffa
No...Stock screen is RGB. The video signal from the stock navi DVD is not compatible with and aftermarket screen with a composite video input.
Besides, the stock DVD navi player will not play standard DVD video discs.
Old Nov 4, 2004 | 06:03 PM
acerys's Avatar
acerys
Thanks a lot
Old Nov 4, 2004 | 10:21 PM
LaPuLaPu's Avatar
LaPuLaPu
I believe there is a converter from RGB to VGA.
Teez Zee's Avatar
Teez Zee
Originally posted by acerys
Thanks a lot
In reality, you might be able to.
The standard lcd display has an internal printed wirig assembly that converts ntsc composite to rgbs. If you remove that board and connect directly to the aftermarket lcd, you can connect.
There are only 4 wires RGBS that need to be connected. You can look at the lcd manufacturers web page to get pin outs.
You probably will not mess up the navi dvd if you hook it up wrong
Easiest way to integrate a dvd player into the Z looks like you purchase a portable dvd player and connect its composite output to the dash unit. That board that you didn't need while connecting the navi unit to the display is the board that you need to convert the composite to rgbs.
Its a little intimidating but you could do it if you wanted to.
Personally, I have a 7" portable dvd that I can just hold if I want to watch movies
lots of luck
m_0g
Jun 3, 2021 10:05 AM
Workshop12
Mar 23, 2020 01:45 PM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Paul.
Oct 16, 2015 07:34 PM
Shane86
Sep 17, 2015 05:33 PM
