Center Dash TV Options
Old Nov 11, 2004 | 04:55 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
FM modulator?
Old Nov 11, 2004 | 05:48 PM
robcassell's Avatar
robcassell
maybe if that will hook up to the stock sound system?...
Old Nov 11, 2004 | 06:58 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Yes, you just pull out the plug for your stock antenna. You then insert this "one into two" splitter. You then plug your antenna wire into one of the ends of the splitter and the FM modulator receiver into the other. You then need to tune your radio to a certain FM channel and there you go.
Old Nov 12, 2004 | 04:28 AM
robcassell's Avatar
robcassell
that sounds great I am very excited about getting the LCD....should my best bet to go with getting A PS2 since it has DVD on it as well, or do you think it might skip a lot?
Old Nov 12, 2004 | 08:58 AM
Srivero297's Avatar
Srivero297
If you get PS2, get the new kind, the really small ones. They are tiny, perfect for fitting in one of those small compartments behind the seats.
Old Nov 25, 2004 | 07:29 PM
BlueDragonZ's Avatar
BlueDragonZ
AHHH, the power of the SEARCH Function...
Very cool, thanks Doc, these are the info I'm looking for, I'm glad I found this thread. I'm in the process of GATHERING any info on how to go about installing a Xenarc screen and a PS2. Any info you guys can contribute is greatly appreciated.
Originally posted by Dr Bonz
Here are links to what I have:
TV Tuner thread:
https://my350z.com/forum/showthread....ighlight=tuner
Computer and monitor threads:
http://www.350zfrenzy.com/forum/show...&threadid=1386
http://www.350zfrenzy.com/forum/show...&threadid=1403
My CoPilot Nav software thread:
http://www.350zfrenzy.com/forum/show...&threadid=1418
Just in case you need it, here is Scafremon's now famous how-to on the center dash console removal:
http://www.350zfrenzy.com/forum/view...center_console
Old Nov 25, 2004 | 08:07 PM
Srivero297's Avatar
Srivero297
PS2 is easy to install. Just need to have an inverter, all of the standard ps2 wires, and then run the power wire to the inverter and the audio/video wires go to the tv's brain.
If you have one of the new ps2's, the tiny ones, one of those small cubby holes behind the seats is a perfect place to mount one, too.
I highly recommend wireless controllers for use in cars though.
Old Nov 25, 2004 | 08:57 PM
BlueDragonZ
Thanks that was one of the areas of concern was powering the PS2. As far as the power inverter, should a 170 watts be sufficient? I was looking at getting this one.
http://www.onlinecarstereo.com/CarAu...roductID=12752
I am getting the newer version which should fit right in the little cubby in the glove box. Should I be concerned with heat since it's an enclosed area?
Old Nov 26, 2004 | 05:52 AM
robcassell's Avatar
robcassell
what about installation, how much is that going to run me to install everything (LCD, PS2, wiring)
Old Nov 26, 2004 | 09:16 AM
Srivero297's Avatar
Srivero297
I dont know if that inverter will do it or not. Honestly, I got my inverter so long ago (transfered it from last car) that I dont know too much about the specs of it.
As far as the enclosed area goes, you shouldn't worry about the ps2 overheating while it is off. When the ps2 is on, you should keep the door to it open. That will provide extra ventilation for it as well as give the controllers somewhere to run the cable. You need the door open for the controllers whether you have the regular controllers or the wireless ones because the signal will not travel through the door on the wireless controllers, however the wireless ones are a lot more convenient because they dont get tangled up and are easier to store away.
Old Nov 26, 2004 | 09:18 AM
Srivero297's Avatar
Srivero297
A new ps2, the little ones, are about 150 i think from circuitcity.com. the wiring comes with them. An inverter costs 30-40, you can also get those at circuitcity. A 7" LCD should cost somewhere between 100 and 200 for a pretty decent quality one. Installation really depends. I did mine myself so, obviously, no charge there. I dont know how much a shop would charge for something like that.
Old Nov 26, 2004 | 10:01 AM
robcassell's Avatar
robcassell
how hard was it to install? I just don't want to get it installed and have the place wire it so i can't use it unless I have the parking brake on! Not that I am going to drive and play PS2, but if I have someone in the car they shouldn't have to suffer
Old Nov 26, 2004 | 10:28 AM
Srivero297's Avatar
Srivero297
its real easy. Took me like an hour. The only tricky part is mounting the ps2. Other than that it is a series of snaking wires through the car, that is all.
To mount the ps2, it is really a matter of personal preference. You can screw it into place with glued-on or velcroed braces, or wire tie it into place in a similar fashion.
As far as snaking the wires, the power wire goes from the back of the ps2 to the inverter. The audio/visual wires (red/yellow/white) go to the matching colored terminals in the brain for the LCD monitor, wherever you have that mounted. (mine is under the passenger seat)
Old Nov 26, 2004 | 09:39 PM
BlueDragonZ
Thanks.
I talked to a guy at Circuit City today and he seemed to think that even a 75 watt inverter is sufficient. I guess I just need to verify this with other people.
So with the wireless controller, I don't have to be in front of the unit for the controller to work? COOL! I was wondering about that.
I got a quote from an installer today and I definately need to install it myself to save $$$.
This is what they want to charge me for installations
$200 LCD
$85 PS2
$80 XM Radio
$40 FM Modulator for XM
$40 XM Antenna
Do you happen to have any pics of your PS2 install? I'd like to see how you actually mounted it. Thanks.
Old Nov 27, 2004 | 07:31 AM
Srivero297's Avatar
Srivero297
I don't have it done in my Z. I did it my other car, '96 BMW M3. And I also did it in my friends 3000GT. I will get some pics of those today if I get a chance and post them up in this thread.
Old Nov 28, 2004 | 12:32 PM
BlueDragonZ
Thanks I'd appreciate it.
sales@czp
Sep 23, 2019 03:30 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
