4 inch comp
Old Nov 16, 2004 | 08:40 AM
og muddbone's Avatar
og muddbone
Default 4 inch comp
Can anyone reccommend an excellent 4 or 4.5 inch component set? I am seriously thinking about doing a 3-way install. I am thinking about using Image Dynamics, a 10 for my sub and their 6.5 for midbass in the doors. ID doesn't make a 4 inch comp only 5.25 to 6.5. I have kick panels that will house a 4inch and tweet fine. If I had to I could modify the kick's to accept a 5.25 but I wasn't trying to go that route.
Old Nov 16, 2004 | 12:17 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
I dont think there is a company out there that makes a 2 way component set with 4 inch mid bass drivers...however
If you want to go super high end you could buy home audio drivers and adapt those over for your install. This would require a four channel amp and a two channel amp because you would be running all the speakers in active not passive crossover.
Highend 4" midrange speaker
http://www.partsexpress.com/pe/showd...number=297-012
someday if I have enough time I may end up doing something like that.
That is the super high end route.
You are better off modifying your kick panels.
Old Nov 16, 2004 | 04:57 PM
stu46's Avatar
stu46
boston acoustics pro 4.5
i'm using it as my center channel.
Old Nov 16, 2004 | 07:33 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
ooooooh really
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350Shadow
Sep 22, 2015 08:30 AM
hardkicks
Sep 20, 2015 12:28 PM
