Audio Builds Audio projects and builds from my350z members
Double Din Stereo Install and Screen
Old Nov 17, 2002 | 09:08 PM
GixxerBB's Avatar
GixxerBB
Default Double Din Stereo Install and Screen
Just finished my double din install using a pioneer 9300 and their DVD player, also installed the farenheit screen in the nav area. The remote sensor was relocated to the head unit area so a hole wouldn't have to be cut in the nav area. I'm installing the speakers and amp as I speak, and hopefully will finish soon. I'm having Diamond Audio Component both front and back and using a MTX 5 channel. Will post the finish pix later.
Link to my install pix
Old Nov 17, 2002 | 09:46 PM
Subw00er's Avatar
Subw00er
the link is bad.
Old Nov 18, 2002 | 07:40 AM
GixxerBB's Avatar
GixxerBB
sorry about the link........i just went on and the site is really slow for some reason. I'll try again later.
Old Nov 18, 2002 | 07:42 AM
GixxerBB's Avatar
GixxerBB
OK, just tried it........link works fine........for now.........
Old Nov 18, 2002 | 09:05 AM
system7's Avatar
system7
Unhappy
Nupe.
Old Nov 18, 2002 | 09:12 AM
GixxerBB's Avatar
GixxerBB
This attaching photo stuff is new to me.........hope it works.
Old Nov 18, 2002 | 09:22 AM
ToddLuc's Avatar
ToddLuc
The issue isn't performance, it is the following message that pops up:
A problem has been detected.
You do not appear to be the owner of this album.
Make sure you are logged in.
Old Nov 18, 2002 | 09:27 AM
GixxerBB's Avatar
GixxerBB
http://community.webshots.com/album/55467796InCOSC
One more try........
Old Nov 18, 2002 | 09:29 AM
mysteriumZ's Avatar
mysteriumZ
Charter Member #101
what screen did you use? did you have to cut the nav box inorder to fit?
Old Nov 18, 2002 | 09:31 AM
GixxerBB's Avatar
GixxerBB
Same screen most other people used.......the farenheit T-5801 i think...........no cutting of the nav necessary, it fits perfect.......only drilled holes in the back to get wires through.
Old Nov 18, 2002 | 10:02 AM
Z99's Avatar
Z99
Dude, your Z look tight man ... I love that logo on your sit. Are you from Diamond Bar, i think i saw you before with your Z
Old Nov 18, 2002 | 10:06 AM
GixxerBB's Avatar
GixxerBB
yup i'm from db........thanx for ur kind compliments..........too bad my car is in a million pieces sitting in my garage while i finish my amp and speakers install........
Old Nov 18, 2002 | 10:07 AM
Z99's Avatar
Z99
GixxerBB, i'm DaVi
Old Nov 18, 2002 | 10:08 AM
GixxerBB's Avatar
GixxerBB
i know fool........haha.
Old Nov 18, 2002 | 10:28 AM
Z99's Avatar
Z99
GixxerBB:
Wanna go to track with my NSX ?
Old Nov 18, 2002 | 10:33 AM
GixxerBB's Avatar
GixxerBB
Typo sir.........i'll take on your Pearl white RSX anyday.
Old Nov 18, 2002 | 10:59 AM
nlauri's Avatar
nlauri
Those seats are awesome! Mind letting me know cost of something like that? Thanks!
Old Nov 18, 2002 | 12:07 PM
GixxerBB's Avatar
GixxerBB
The seats with the protective coating came out to be $1k.....but by ordering the seats with the dealer, they actually lowered my APR which made it a pretty good deal.
Old Nov 18, 2002 | 12:36 PM
350Now's Avatar
350Now
Default Seats and Unit
Hey GixxerBB,
Are those seats factory Nissan seats or custom? They are pretty sweeeeettt. Also do you plan to cover the little gap between your head unit and the dash panel? What would you say is the hardest part of your install so far?
Thanks,
Old Nov 18, 2002 | 12:47 PM
GixxerBB's Avatar
GixxerBB
The seats are katzskin i think that the factory sub out to install. The gap using the supplied trim ring around the head unit actually covers pretty well.........for now i think it's fine. The hardest part about the install is running the cables and taking everything apart and remembering how to put them back together. I ran the power cables through an existing hole in the firewall which was hidden behind the fuse box.......i had to take out the plastic cover and the battery in order to get to it. Also running the speaker wires from the amp to the door is time consuming too........i finished one door yesterday and hopefully will finish the other today. But it'll all be worth it when it's finally done.
