Audio Builds Audio projects and builds from my350z members
Alpine LCD in the 350Z
Old Mar 10, 2003 | 10:35 AM
Jasonj30's Avatar
Jasonj30
Default Alpine LCD in the 350Z
Hi, I have just worked on my friend's 350Z recently. I custom installed an Alpine Tme-m760 6.5inch lcd into his car. The Lcd fits prefectly with some proper cutting. Here are some pix:
Old Mar 10, 2003 | 10:39 AM
klee.007's Avatar
klee.007
It looks like the bottom and sides are cut off... unless the pics are wrong... was it an easy install beside that?
Old Mar 10, 2003 | 10:41 AM
Jasonj30's Avatar
Jasonj30
It took me about 5 hrs to do everything (including installing the headunit)
better pic:
hey man, u own a prelude? i think i have seen you on preludeonline.com haha
Old Mar 10, 2003 | 10:48 AM
Jasonj30's Avatar
Jasonj30
a pic of the area that I cut:
Old Mar 10, 2003 | 10:58 AM
noahbuddy's Avatar
noahbuddy
getting ready to do this myself... could you outline the areas you cut? Also, how did you cut it? I'm sure my jigsaw would make mensed meat out of that plastic.
Old Mar 10, 2003 | 11:32 AM
whatever's Avatar
whatever
Veteran
was cutting absolutely needed? I thought I saw some installs without cutting? I'm thinking of getting this screen but if I have to cut.... I think I might go back to the drawing board.... trying to keep everything as stock looking as possible without making any changes to the car.
Old Mar 10, 2003 | 12:11 PM
KJ-350's Avatar
KJ-350
then go with a FARENHEIT T-7001MHR! It is a widescreen LCD and requires 0 cutting! You would end up with more "viewing" are in the dash too since it has no external buttons! The LCD will completely fill that up corner to corner and sits 99% perfectly flush!
KJ-350's Avatar
KJ-350
another
Old Mar 10, 2003 | 12:12 PM
KJ-350's Avatar
KJ-350
last
Old Mar 10, 2003 | 01:23 PM
whatever's Avatar
whatever
Veteran
thanks kj-350.
I originally thought about using the 7001 but after rouxeny's review
https://my350z.com/forum/showthread....hlight=pioneer
I decided to look else where since I will be primarily using this for Nav and rather have the clean text...
Anyone hookup the Xenarc with an alpine or pioneer nav?
Old Mar 10, 2003 | 02:09 PM
klee.007's Avatar
klee.007
better pic:
Yup, I do... I'm a moderator there! What were you doing there? Where you a lude owner before?
Old Mar 10, 2003 | 02:27 PM
ccondo's Avatar
ccondo
Default Installed the same monitor...
My installer installed the same monitor. Except it isnt flush behind the pocket. It is actually in front of the pocket, where you can see the edges of the monitor. It doesnt look bad, and we were worried that if we tried to flush it, you would see edges of cut plastic.
Here is a pic.
Old Mar 10, 2003 | 02:38 PM
rodmanj's Avatar
rodmanj
Default Cutting
I am thinking about getting the same apline screen,
So please tell us why the cutting was needed, because there
are many installs that required no cutting.
Old Mar 10, 2003 | 02:42 PM
ares's Avatar
ares
Veteran
he obviously cut to make room for the buttons that are on the side of the screen, tho he did a great job and you would never imagine that it was cut... looks totally stock..
youd only run into problems if you wanted to remove it, but Id imagine that part is about 5$ at most.
Old Mar 10, 2003 | 03:27 PM
rodmanj's Avatar
rodmanj
Default Cutting Again
Yes I can see that cutting was done for the buttons, but other
installs did not require cutting "I think" so if anyone has any info
on the Alpine LCD screen installation. PLease post
Old Mar 10, 2003 | 03:58 PM
qirex's Avatar
qirex
Default Re: Installed the same monitor...
Here is a pic.
which ALpine HU is that?
does it send track data (mp3 names etc. ) the the screen? or just video?
BTW has anyone figured out how to bypass the Alpine safety feature that prevents use of any input besides NAV while driving??
btw - another advantage of the tme650 is the 3 additional inputs besides the NAV. One has a mirror mode and automatically switches to that input when the reverse light is senses (backup cam!!)
Old Mar 10, 2003 | 04:08 PM
Anyone2u's Avatar
Anyone2u
Charter Member #82
Default Re: Cutting Again
So far, every single Alpine monitor that has been installed in the 350Z has had to have some "minor" cutting done to make it fit, including mine. The Fahrenheit monitors, from what I have seen on this board, do not require any cutting.
(Alpine TME-M760 and 7996 HU, BEL 875 Remote Radar)
Old Mar 10, 2003 | 05:14 PM
Jasonj30's Avatar
Jasonj30
Originally posted by ares
he obviously cut to make room for the buttons that are on the side of the screen, tho he did a great job and you would never imagine that it was cut... looks totally stock...
Thankyou
Old Mar 10, 2003 | 05:17 PM
Jasonj30's Avatar
Jasonj30
I m still a lude owner. I go to preludeonline alot but never post much tho. I m here cuz i like the 350Z
Old Mar 10, 2003 | 07:02 PM
phillips69's Avatar
phillips69
Default how's that 7996?
Hey Anyone2u,
How do you like your HU? I was thinking about putting that same 7996 in mine too...DVD w/ DTS worth the expense over an Alpine CD only?
