Audio Builds Audio projects and builds from my350z members
AVIC-D3 installed! Pics! Reverse wire location pic!
Old Sep 3, 2007 | 05:26 PM
scottrocket's Avatar
scottrocket
I ended up just bending the brackets a little and it's flush now and looks great, only thing I couldn't figure out was the speed sensor wire, no clue where that is, tried searching the forums and didn't understand what the wire diagram sticky was saying so that's all i need to hook up for it to be 100% done. If anyone could fill me in on that it would be appreciated
Old Sep 6, 2007 | 12:33 PM
eddieclayton's Avatar
eddieclayton
Hey fellas, the AVIC-D3 is a nice unit indeed (once you do the bypasses)! I just put one in my Impreza and I'm probably going to be getting another one for my Z. Just a FYI, you can probably get away with putting the GPS antenna under the plastic trim for the gauge pods, GPS will go through plastic (mine is under the clock pod in my impreza)... stealth FTMFW! In addition I didn't hookup the VSS wire and it's still accurate as hell.
In my impreza:
Old Oct 6, 2007 | 04:04 PM
SolarOrangeZ's Avatar
SolarOrangeZ
1. Where do you run the bluetooth stuff in the Z?
2. Is the reverse wire for the 2007 350z also teal?
Old Oct 7, 2007 | 09:47 AM
eod nhoj's Avatar
eod nhoj
Default d3 install
here is a link that shows the d3 install on the z.it shows where tht vss wire is also
https://my350z.com/forum/audio-and-video/278145-avic-d3-install-guide.html
Old Oct 7, 2007 | 11:31 AM
SolarOrangeZ
I am all over the VSS wire. Wondering if there is access to the reverse wire up front so I don't have to run a wire all the way in the back.
Old Oct 7, 2007 | 06:16 PM
doug's Avatar
doug
Originally Posted by Voboy
1. I put mine underneath the plastic on the rear strut bar.
i had mine on the dash at one point.. i later moved it to the rear strut bar
Old Oct 10, 2007 | 07:30 PM
eightyeight's Avatar
eightyeight
i'm not sure if this is my first post or not. but I was wondering if you guys recommend me trying this for my first stereo install or should i get it installed by a shop. I have a complete stock stereo but im buying the d3 and a jl sub (not sure if one 12 or two tens: which is better) and an amp.
And any one with an iphone using the d3 with the ipod plugin? I think it would be sick if you had the plug come up somewhere in the open and connect a dock to it so when u get into the car you can just stick your iphone into the dock and bam. and another side question: is it possible to get the bluetooth to work with the iphone?
sorry for all the questions and don't mean to jack the thread.
but great job on the install I really want to try this.
Old Oct 11, 2007 | 05:56 AM
zboy2003's Avatar
zboy2003
I just installed the AVIC-Z2 with all the goodies, need to post some pic of it.
Old Oct 11, 2007 | 08:19 AM
eightyeight
Originally Posted by zboy2003
excuse me for not being a car audio guru
Old Oct 11, 2007 | 08:25 AM
deviljon's Avatar
deviljon
the install can be done yourself, it's not difficult at all. this write-up is VERY helpful and will easily walk you through it in detail.
https://my350z.com/forum/showthread.php?t=278145
don't be afraid to give it a shot, most shops will charge a pretty penny and even extra to do the simple bypass.
as for the iphone, i'm not sure exactly how it will work with the d3. i know some of the new gen. ipod's dont work with this unit. you can go on avic411.com and search it, they have plenty of threads there that cover what works and what doesn't.
Old Oct 11, 2007 | 04:26 PM
eightyeight
yeah and i saw some more guides to on avic411.com (thanks for site refrence) if i got stuck somewhere on his guide. i plan to also use that one kit from zaran sub install kits (the two subs behind the driver and passenger seat) cuz i like the stealth install and dont nead huge base
Fixxxercask
Cooling System
Nov 5, 2015 03:21 AM
kyin
Oct 15, 2015 05:54 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
nanotech
Oct 2, 2015 05:02 AM
