Audio Builds Audio projects and builds from my350z members
My lil setup
Old Nov 2, 2007 | 04:42 AM
  #61
StreetOC192's Avatar
StreetOC192
Originally Posted by d4k0t4
LAWL? If you goto the JL Audio website and the Image Dynamics website..you will see that the Volume requirements are not the same.
Do you need me to post links because I can?
Here, I'll save you the effort........
IDMAX12D2V.3
Recommended enclosure: 1.30 -1.52 cu.ft. sealed
Recommended 1000 watts RMS
JL 12W7
Recommended enclosure: 1.375 cu.ft. sealed
Recommended 750 watts RMS
Looks to me that they would be interchangeable in a given box. You know, since even the most demanding sub has a tolerance of AT LEAST 20% sealed. But I'm sure you knew that.
Old Nov 2, 2007 | 06:19 AM
  #62
d4k0t4's Avatar
d4k0t4
IDMAX12D2V.3
JL 12W7
I just entered the 1.52 cu feet for each subwoofer in my TERMPRO. The frequency response curves for each woofer are totally different. But Im sure you knew that would happen? By the way, which IMAX does doug have? The D2 or the D4....that could make a difference too.
Old Nov 2, 2007 | 06:21 AM
  #63
blasian's Avatar
blasian
So now you are saying you need to put the subs in boxes where the frequency response curves are the same to be a fair comparison
Old Nov 2, 2007 | 06:25 AM
  #64
d4k0t4's Avatar
d4k0t4
Do you even know how to do that? If so, explain.
Old Nov 2, 2007 | 06:32 AM
  #65
blasian's Avatar
blasian
I guess you missed the point
Can't tell Louisiana folks nothing without them missing the point
Old Nov 2, 2007 | 06:38 AM
  #66
StreetOC192
The voice coil config on the IDMAX should have no impact on the enclosure requirements. What 'might' make a difference would be which version (v2 or v3). The specs above are from v3. Not sure if any difference with the v2.
Of course there will be different response curves, they are two different subs with different specs. Response curves in software are ok for a baseline comparison, but there is no replacement for real world listening in a car. The car's acoustical characteristics can make all the difference in the world.
Old Nov 2, 2007 | 06:53 AM
  #67
d4k0t4's Avatar
d4k0t4
Well my point is....your not gonna get the optimum sound for each subwoofer in the same box.
Old Nov 2, 2007 | 06:57 AM
  #68
d4k0t4's Avatar
d4k0t4
Also regarding ..is the IMAX a D2 or D4......Doug said he was using the same amp on both the IMAX and then on the JL 12 W7. The amp being used makes a huge difference as well because the JL 12 W7 is a 3 Ohm sub. Yet again ...installation technique.
Old Nov 2, 2007 | 07:08 AM
  #69
doug's Avatar
doug
lawl. So is he saying that two different subs with the same air space requirement shouldn't be used in the same type of box to compare?
I posted "k" because thats my nice way of telling women to STFU when they are blabing in your ear.. they know they are wrong but will come up with everything else in the book.. it goes over so much nicer
  #70
blasian's Avatar
blasian
Umm... okay.
Old Nov 2, 2007 | 07:09 AM
  #71
blasian's Avatar
blasian
I hear ya, I'm pretty much done with arguing with people from LA
  #72
doug's Avatar
doug
dude you win... JL is the best... JL is better than IDMax .. whatever gets you to stop whining.. YOU WIN.. YOU DA MAN!!
Old Nov 2, 2007 | 07:10 AM
  #73
d4k0t4's Avatar
d4k0t4
Im from Mississippi...Unfortunately Im stuck in LA because of my job.
Old Nov 2, 2007 | 07:12 AM
  #74
d4k0t4's Avatar
d4k0t4
Its not about winning dude.....You get on and bash the dudes pictures and didnt expect someone with a little stereo knowledge to jump in and say something.
  #75
blasian's Avatar
blasian
lol even worse.
But yeah, JL is the best of the best of the best and I didn't get it because it was out of my price range.
Old Nov 2, 2007 | 07:13 AM
  #76
blasian's Avatar
blasian
There you go doug
Old Nov 2, 2007 | 07:16 AM
  #77
d4k0t4's Avatar
d4k0t4
Talking
lol even worse.
There ya go ckpilot
Old Nov 2, 2007 | 07:18 AM
  #78
doug's Avatar
doug
see this is how women get black eyes.. i let it go.. i said you won.. i killed the argument.. what do you do? you start to get cocky .. sometimes you have to realize when its time to let things go.. i can see you don't know how to do that.. you're wrong.. you've been wrong from your first statement that JL is the best equipment.. you've been wrong trying to argue the w7 is better than the IDMax .. yet you still going..
sometimes it takes a back hand to a b!tch before they will shut up
Old Nov 2, 2007 | 07:34 AM
  #79
blasian's Avatar
blasian
There ya go ckpilot
Your sarcasm detector is not working. May want to fix it.
Old Nov 2, 2007 | 07:41 AM
  #80
d4k0t4's Avatar
d4k0t4
Dude your not letting it go bet saying the bs in the bold.
Ive proved myself with information to support it. May want to go back and read some of the posts. Your information was based on opinionated comments like "it blew me away" or people in the drive thru said it was loud.
And now your getting so mad that my data is actually making sense and making you look like a jack *** that your wanting to hit someone...Maybe you should go back to your trailor and go beat your wife some more. Take some of that agression out somewhere else.
