Audio Builds Audio projects and builds from my350z members
VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
Old Jan 17, 2008 | 07:05 AM
  #141
SuperBlack350z's Avatar
SuperBlack350z
The T1 did hit hard and sound good in the z. It was one of the better set ups i heard in a z needing such little air space.
Old Jan 17, 2008 | 07:06 AM
  #142
VO...'s Avatar
VO...
Administrator
Originally Posted by StreetOC192
There's gotta be a reason. That just doesn't sound right. It actually sounds as if it's clipping (not finishing th full excursion).
It didn't finish full excursion, but didn't sound like it was clipping. I've heard clipping before. If I'm not mistaken, clipping is when the sub starts it's excursion then makes a popping noise and returns to normal position.
This was more like it would start it's excursion, then die down to about half way and finish the bass note.
Normally when tuning the gains, you would use a test tone cd, but a music cd could work also so long as you KNOW the ins and outs of the song used (sounds like you do).
Werd, I do.
What is this sub crossed over at? Did you try reversing phase? Does the amp have a subsonic filter?
My amp has two features for filtering/crossover.
1. HP-LP-AP dip switch (I have it set at LP-Low Pass)
2. Frequency cut off potentiometer
The potentiometer goes in incrementes of about 25hz. I have mine set to not play anything above 55hz in my sub.
Old Jan 17, 2008 | 11:27 AM
  #143
VO...'s Avatar
VO...
Administrator
No suggestions? Guess I'm stuck with a sub that doesn't deliver...
Anyone want to buy it?
Old Jan 17, 2008 | 11:58 AM
  #144
StreetOC192's Avatar
StreetOC192
Sorry Vo, I'm cranking this through my brain to see what I can come up with.
Did you make sure you have no leaks in the enclosure?
Old Jan 17, 2008 | 12:03 PM
  #145
350zspl's Avatar
350zspl
are you crossing over double at sub amp and at head unit
Old Jan 17, 2008 | 12:05 PM
  #146
StreetOC192
I wish I was in Texas right now for 3 reasons......
1) the gorgeous women
2) the warm weather
3) to hear the sub so I would know exactly what you are hearing/seeing
Old Jan 17, 2008 | 12:14 PM
  #147
350zspl's Avatar
350zspl
i am wondering if your low pass setting at 55 hertz is set on amp and set on Hu the same way
Old Jan 17, 2008 | 12:30 PM
  #148
VO...'s Avatar
VO...
Administrator
Thanks.
No leaks..
  #149
VO...'s Avatar
VO...
Administrator
No sir. I don't use the HU's crossover. I just let it pass everything....
Old Jan 17, 2008 | 12:31 PM
  #150
VO...'s Avatar
VO...
Administrator
+1
2) the warm weather
-1. It's been crappy all week. Lots of rain.
Old Jan 17, 2008 | 12:32 PM
  #151
MethodRN's Avatar
MethodRN
For Sale
Thanks.
No leaks..
I can vouch fro Val's work, this guy is too meticulous for it to be a simple problem like that.
Old Jan 17, 2008 | 12:34 PM
  #152
VO...'s Avatar
VO...
Administrator
werd.
Old Jan 17, 2008 | 12:35 PM
  #153
VO...'s Avatar
VO...
Administrator
Imma double check the HU setting tonight. Nothing should have changed though. I haven't reset any options since my T1 was working...
Old Jan 17, 2008 | 12:44 PM
  #154
StreetOC192
Did you do a final volume check when you were done?
Old Jan 17, 2008 | 12:53 PM
  #155
VO...'s Avatar
VO...
Administrator
The last thing to be tuned was the sub. All other components were tweeked already, so once the sub was tuned that was pretty much it. I'm not sure I understand the question..
Old Jan 17, 2008 | 01:54 PM
  #156
350zspl's Avatar
350zspl
if you are using low pass crossover on amp than you are not needing low pass crossover setting on head unit
if you are using both lp on amp and hu you double crossing over
try turning off head units low pass crossover and only using the low pass on amp
what are the settings on your amp for low pass choices?
Old Jan 17, 2008 | 02:01 PM
  #157
SuperBlack350z
Last but not least, maybe the sound of this subwoofer isn't for you. Like you said, you are kind of into the very deep and loud bass. RF has always delivered this with their subs. Boomy loud , internal shaking bass that sounds good. I'm also into that bass as well and sometimes my jl w7 leaves me wanting more. But my w7 sounds good with most music and gets loud enough for me for right now.
One thing i use to read about FI Q series subs is that some people weren't happy with the sound until a week or two after the sub broke in. They sound it gradually sounded better. Maybe you can try this before you resort to buying something new.
Old Jan 17, 2008 | 02:02 PM
  #158
VO...'s Avatar
VO...
Administrator
I'm not using the low pass cross over feature on my HU, to my knowledge. I had not been using it on my previous setup, and have not changed any settings since then.
LP on amp is already enabled
The sub amp only has a potentiometer that gives you the ability to pick the frequency cut off point. I currently have it set to filter out everything above 55hz...
Old Jan 17, 2008 | 02:04 PM
  #159
VO...'s Avatar
VO...
Administrator
Could be
I never heard of this, but I'm willing to give it a shot. I have an outdoor show on Sunday. I should be able to give it alot of play time then....
Old Jan 17, 2008 | 02:08 PM
  #160
350zspl's Avatar
350zspl
call Scott in Nevada expalin what the symtoms are
might need the poly fill but i don't think so
run it by Scott make the call let me knwo if he has any ideas
the sub is 100% capable of being better on music , louder , deeper
call Scott before you drive yourself nuts over this
