Audio Builds Audio projects and builds from my350z members
VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....
Old Jan 4, 2008 | 11:22 AM
  #41
StreetOC192's Avatar
StreetOC192
Originally Posted by 350zspl
oc192 is right 2" might be just perfect , but 2.25 or 2.5 will definelty be good
Like my girl tells me, longer is better
Old Jan 4, 2008 | 11:23 AM
  #42
VO...'s Avatar
VO...
Administrator
Originally Posted by StreetOC192
When playing the game of "slowing down sound waves", it's more a matter of how thick the layer is on the walls and how dense you install it rather than the amount you put in. If you have a raw enclosure that is close to 1.5 cu ft, I would try without polyfil as 350zspl says. you can always add it if the sub sounds 'flat'. if your enclosure is closer to 1 cu ft, then I would throw in a pound of polyfil (cheap insurance at $4 a bag at walmart).
Old Jan 4, 2008 | 11:24 AM
  #43
VO...'s Avatar
VO...
Administrator
Understood...
Old Jan 4, 2008 | 01:33 PM
  #44
Zrealsoon's Avatar
Zrealsoon
Tough luck if you get a flat huh? Won't matter... you can just pound out the music while you wait for someone to find you a wheel!
Old Jan 4, 2008 | 01:57 PM
  #45
VO...'s Avatar
VO...
Administrator
Werd.
Old Jan 4, 2008 | 02:01 PM
  #46
StreetOC192
Since it's a show car, hopefully that's not a big issue
Old Jan 4, 2008 | 03:54 PM
  #47
smaha's Avatar
smaha
what kind of fan you using to pull air outta your amp enclosure?
Old Jan 7, 2008 | 07:03 AM
  #48
VO...'s Avatar
VO...
Administrator
Default Updates...
Saturday I made good progress. Woke up early and hit Home Depot again. Picked up some liquid nails and a sheet of 3/4" MDF. One item I couldn't find, which I will need soon, is a compass or device that can make 10 or 11 inch diametered circles. The biggest they had could only make 9" circles. When the sub arrives, it might have a template to trace, but I don't want to take a chance.
Can anyone tell me where to pick one up?
I took all my measurements down and made a sketch on paper, being careful and making sure to double check all my measurements. For the side panels, I just traced out the old thinner plates, cut out new ones from the MFD, then used liquid nails to bond them together. I placed heavy cinder blocks on them so the two pieces of wood would mash flush with eachother. They sat all night and cured...
Attached Thumbnails VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3353.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3354.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3359.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3361.jpg
Old Jan 7, 2008 | 07:05 AM
  #49
VO...'s Avatar
VO...
Administrator
Here's a few test fit pics of just the side panels in place. You can see how much more the floor board will be elevated compared to the original baffle board...
Attached Thumbnails VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3363.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3362.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3364.jpg
Old Jan 7, 2008 | 07:07 AM
  #50
VO...'s Avatar
VO...
Administrator
Here's a few shots with the new top baffle board in place. I haven't cut the hole out because I need a large compass to trace the circle and I'm still waiting on the sub also. In the last pic you can see I've already made the measurements as to where the center of the new hole should be, in realation to the original baffle board. I just recieved an email from FI by the way. The sub was built and shipped today. It will arrive on Friday.....
Attached Thumbnails VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3365.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3366.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3367.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3369.jpg   VO's Sub Enclosure Makeover Fr3ad In Progress..FI Q series 12" sub..RF power....-imgp3368.jpg
Old Jan 7, 2008 | 07:11 AM
  #51
350zspl's Avatar
350zspl
stop posting and start cutting
just playin
take pics along the way
peace
Old Jan 7, 2008 | 08:27 AM
  #52
VO...'s Avatar
VO...
Administrator
Will do.
Any idea where to pick up a compass large enough to create a 12" traced out circle?
Old Jan 7, 2008 | 08:30 AM
  #53
350zspl's Avatar
350zspl
Originally Posted by vo7848
Will do.
can you turn your T1 sub upside down remove gasket and use that as a template for 12"
Old Jan 7, 2008 | 08:44 AM
  #54
VO...'s Avatar
VO...
Administrator
I could, but was thinking about what you said about refurbishing it. Also, I'm not sure what the Fi sub is going to call for either. The mounting diameter might vary. What I was thinking about doing if push comes to shove, is tieing some dental floss to a pick and using that as a makeshift compass...
  #55
Zrealsoon's Avatar
Zrealsoon
Will do.
Well..
1 Nail
1 piece of string exactly 6 inches in length.
1 pencil.
String ties to nail and pencil.
Nail in center of sub location, pencil circles around it?
edit: ah ya. ya allready thought that :-)
Crude but if your careful just what you need right?
Old Jan 7, 2008 | 08:47 AM
  #56
VO...'s Avatar
VO...
Administrator
Well..
1 Nail
1 pencil.
Werd. That's what I was gonna do, but figured I'd buy something to add to my tool collection...
Old Jan 7, 2008 | 09:08 AM
  #57
350zspl's Avatar
350zspl
FI 12" Q cut out 11.125"
Old Jan 7, 2008 | 09:22 AM
  #58
VO...'s Avatar
VO...
Administrator
Thanks guy.
The cut out for the T1 12" measured at 10 7/8" is I remember correctly. I'll leave that one as is, and just cut the correct side for the new top baffle....
Old Jan 7, 2008 | 10:13 AM
  #59
StreetOC192
I'm sure you could find one of these at Home Depot or Lowes or somewhere else near you. This is of course if you are going to use a router to make your hole.
http://www.partsexpress.com/pe/showd...number=365-250
Old Jan 7, 2008 | 10:40 AM
  #60
VO...'s Avatar
VO...
Administrator
That's a cool gadget. Too bad I don't have a router. I'm just going to do it with the dental floss and pick method.
I was on the partsexpress site this morning ordering mounting screws. I found the t-nuts at Home Depot, but no 2 inch or larger screws. Maybe they were out of stock. I just ordered them from partsexpress. I ordered their "hurricane nuts" also. It's the new version of a T-nut, without the little spikes(part# 260-775). A bag of 50 was only a few bucks.
They also have a new sound dampening spray I was looking at. It comes in a aresol can. My entire rear and hatch, as well as front doors are already sound deadened. I'm not sure if the new sub is going to cause any new rattles or not. I'll wait and see before laying anymore sound dampening....
