Audio Builds Audio projects and builds from my350z members
The start of my 350Z sound project....PICS
Old Nov 13, 2008 | 07:59 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
awesome work!!! cant wait tosee the final results
what shop do you work at by the way up there? do you know Tim from hertzemall?
Old Nov 13, 2008 | 08:11 AM
Kwame's Avatar
Kwame
Originally Posted by orgasm_donor
I have since removed the factory Nav unit alltogether because I am running the JVC Nav (which looks and performs infinitely better!). I am running the TMEM screen on the second zone of the JVC deck so I can run navigation or the display screen AND I can watch movies at the same time (not that I would while I am driving of course )
It'll make for a really concise and complete entertainment system.
Thanks for the response.
I know Kenneth Kaniff, from Connecticut!
Sorry I was just listening to some old Eminem in the car.
Old Nov 13, 2008 | 08:32 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
lol yeah...melt in your mouth...
Old Nov 13, 2008 | 11:59 AM
orgasm_donor's Avatar
orgasm_donor
Why yes I do! Tim and I go back a long ways.
I work at SoundsGood Auto Services.
Thanks for the props homies! Word.
Old Nov 13, 2008 | 11:38 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
hehe, is this Mike? if so i see you from time to time on the insider forum hehehe infact you replied to a thread of mine before
keep up with the pics mang
Old Nov 14, 2008 | 07:05 AM
orgasm_donor
Thats me! But what I have no idea what forum you are talking about.
Old Nov 14, 2008 | 07:49 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
sorry i mean the orgasm donation forums lol
Old Nov 18, 2008 | 08:57 PM
orgasm_donor
Double screen update!
And a random picture of me lying in the trunk before I started the hushmat!.
Old Nov 19, 2008 | 05:02 AM
Kwame's Avatar
Kwame
^WTF?
Old Nov 19, 2008 | 10:37 AM
folgrz's Avatar
folgrz
LOL
Old Nov 19, 2008 | 10:54 AM
orgasm_donor
Originally Posted by Kwame@z1
^WTF?
Please don't tell me you haven't curled up into a ball with a blanket in the back of your car at some point.
Old Nov 19, 2008 | 12:21 PM
Kwame's Avatar
Kwame
The economy isn't THAT bad.
Old Nov 19, 2008 | 01:05 PM
gmueip's Avatar
gmueip
Hi Kids!
Originally Posted by sno
Jesus.
+1
Old Nov 19, 2008 | 03:23 PM
Get_Zwole's Avatar
Get_Zwole
lmao that was great. I doubt i could fit in there lol.
Old Nov 19, 2008 | 06:44 PM
Diesel350's Avatar
Diesel350
Damn that is an awesome project. I definitely want to some sound deadening to my car. Way to many rattles and annoying tire noise.
Is there any way you can give a breakdown on how you took everything apart or is there a guide somewhere that you used? I am especially interested in how to take the door off?
Old Nov 19, 2008 | 08:11 PM
orgasm_donor
Well, there are a lot of details but it is really not too diffucult especially when it comes to all the rear panels.
For the Glass in the doors:
1) Remove door panel
2) There are two access holes which lead to the two bolts that hold the glass in place. Mark where the adjuster washer sits so its easier to line up later one when re-installing.
3) Take the two window bolts out **make sure you have a spotter to hold the glass in place!** then remove the window up and out.
4) Take the 8 or so 10mm bolts out of the metal outer skin. That outer skin will come off fairly easy but may need some persuading.
Thats pretty much it. When you are sound deadening make sure that you don't apply deadener to the seam between the crash beam and the door skin. Moisture needs to run down the door skin and past this seam to the bottom. If it can't, it will promote rust. I applied hushmat to the outer skin, the metal inner skin and all around the non-removeable inner skin (including the bottom of the door inside). Again, make sure you don't cover up the drain holes - they are there for a reason!!!
Hope this helps a bit.
Old Nov 25, 2008 | 04:32 PM
Diesel350's Avatar
Diesel350
Can you give me an idea of how many sq ft you used on the trunk, cubby areas, floor boards and doors?
Old Nov 25, 2008 | 05:33 PM
  #38
orgasm_donor
- about 12 square feet per door
- about 14 square feet for the ceiling
- about 8 square feet per cubby
- about 14 square feet for the floor
- about 14 square feet for in front of the strut brace
- about 6 square feet per side for the B-C piller areas
- about 12 square feet for the hatch lid
- about 24 square feet for the trunk area
Those are estimates but should be pretty close
Old Dec 18, 2008 | 10:20 PM
  #39
orgasm_donor
Check out part 2 of my build!
https://my350z.com/forum/audio-build...tall-pics.html
Old Jan 10, 2009 | 06:14 AM
  #40
ninor's Avatar
ninor
Awesome work man! I'll be getting some comps up front and a 10" sub soon and I wanted to deaden some of my car but not go as nearly as extreme as you did.. what do you think what are the most critical areas to deaden in a Z?
