pics of new system
Originally posted by narkotic
Am I the only one that thinks those amps will cook under the sunlight?
Originally posted by onecoolee
oooohhh...another Phoenix Gold fan ! I love it... nice choice of equipment, and I bet that monster PG amp puts out some serious power into your subs. Nice install, a little too flashy for me, with the high dollar amps in plain view (I hope you got an aftermarket security system installed), but a good job, and I can only image what those 2 10w6v2's sound like being pushed by that PG monster...
The only thing I would change is the metal looking piece around the sub enclosure, I would make that vinyl so that your sub enclosure matches your interior, other than that, I love the install.
When they did my install, they were supposed to make me a cover to fit in the cut out to cover the amps so they can hide a bit. I have to go back this friday for a few minor things and will for sure be checking on it. The metal peice I didnt like it that much either at first but it has kind of grew on me but vinyl would look good also. Something to think about. Thanks for the comments and always ride with PG!
As far as cooling goes, the PG amps stay pretty cool...and the Titanium (ZX) series have built in inductive cooling fans (pull air in through the sides, cool the fins and push the warm air out the top...I run my ZX600ti at a 1 ohm bridged load, and it stays pretty cool. Mine is not sunbathing though either, but I doubt you could get it to shut off, unless you were going full output before clipping for at least 10-15 minutes--which is defintely long enough to make your ears bleed.
Originally posted by nissan_fanatic
bignate7, do you still have access to your spare? If so, how and can you post pics if they created something for you to be able to access your spare.
Justin100
Nov 29, 2015 03:58 PM
