S2K Engine Start Button install write-up
Old Apr 26, 2007 | 10:20 AM
  #121
ldawg32's Avatar
ldawg32
wow i wish someone lived near me to help me out with this. me likey
Old Apr 29, 2007 | 10:23 AM
  #122
TartanPimpernel's Avatar
TartanPimpernel
Shame no-one makes a shifter with a `hidden` button
This is the setup on the Mercedes McLaren SLR
-c-
Old Apr 29, 2007 | 10:33 AM
  #123
gringott's Avatar
gringott
They do make such a hidden button, for example, TurboXS makes one, among others.
Old Apr 29, 2007 | 11:35 AM
  #124
Mike Wazowski's Avatar
Mike Wazowski
I like that
Old Apr 30, 2007 | 04:13 AM
  #125
TartanPimpernel
you`re not wrong, good old google....
Old Jun 8, 2007 | 08:21 PM
  #126
Floyds_racing's Avatar
Floyds_racing
empty your box out!
Old Jun 19, 2007 | 03:29 PM
  #127
HockeyZ39's Avatar
HockeyZ39
I had two ideas, would the button fit in the center console on the roof? Where the sun glass holder is? there seems to be about 3 or so inches in there.
Also i was thinking tapping into something like the rear defogger would be pretty sweet for a stealth install. When people are in your car and you hit the rear defoger to start that would be pretty cool.
As of now I am probably leaning toward the center inbetween the seats if I can find a spot my arm will not be hitting it.
Old Aug 10, 2007 | 05:14 PM
  #128
kvp35's Avatar
kvp35
is there anyway to set this up so that you don't need to put the key in and turn nearly all the way? I mean its obvious that this is more for entertainment then utility-I understand that theres a transponder in the key- is there something you can do like the new Infinity's where you just have the key in the car or close to the ign and then press the button to start?
Old Aug 10, 2007 | 05:38 PM
  #129
blaukal's Avatar
blaukal
the short answer is "no". check out this thread, where it is discussed (near the middle of the thread):
https://my350z.com/forum/audio-video-and-electronics-diy/268183-2007-altima-engine-start-stop-button-project.html
Old Aug 13, 2007 | 07:25 PM
  #130
kvp35's Avatar
kvp35
found it thanks man. Still a fun project.
Old Oct 6, 2007 | 09:02 PM
  #131
DeusExMaxima's Avatar
DeusExMaxima
Wonder if this would work in a 2005 maxima? Also, what is the difference between this button and the 2007 Altima button form an electronics and logistics point of view?
Old Oct 6, 2007 | 09:05 PM
  #132
DeusExMaxima
Originally Posted by Greg'Z33
I've got an alternate idea for the '06 6MT 350Z which has a different center console and that is this: Make the hazard swith an "Engine Start" button. Relocate the hazard switch to the blank plate next to my heated seat switches using either a TCS or VDC OFF switch. I think I'll tackle this after I move from Florida to Texas in the next couple of weeks.
Theres a great idea!!!
Here is my center console:
Old Oct 20, 2007 | 07:29 PM
  #133
cbr900son's Avatar
cbr900son
-c-
damn that would be hot now to find a nice shift like that and do it!
Old Oct 21, 2007 | 10:09 PM
  #134
DeusExMaxima
Call Mercedes and see if they have one in stock.
Old Oct 22, 2007 | 05:53 AM
  #135
punish_her's Avatar
punish_her
It looks like every one wants to show it off. What about concealing it, like under dash to the right?
Funny thing, I got 3 keys from the dealer, so technicaly if I end up bypassing the start and find a nice close place in the colum to mount the chip it can start with out the key. Yes you would need a bank of switches for the 12V constand, Ignition, accesory, and probably a hidden ground cut out to prevent theft.
Starting to make my mind wonder of the possibilities. I know KPTaylor is trying for a full keyless start. This maybe the easier way.
EDIT:
According to your own diagram if you cut the harness as described and wire directly to the start/stop switch, wire up the ACC line, and 86 to ground.
There are 2 ways you can go about this for vehicle anti theft. 1) If you have 3 keys like me. Cut off one key leaving the plastic key thob and afix it in your upper steering colum near the ignition harness. 2)If you find where the actual transponder is you can do a little surgery and move it to the ash tray or some thing so you doent even need to butcher a key.
At that point you get in the car place your key in the ashtray and push the start button. Thats it. Im gonna look up the wiring and see where the transponder is.
EDIT EDIT: Page BL-120 in the service manual show the location of the NATS antena for the chip. All the way to BL-138 is dedicated to diagnostics and wiring. So it looks like if you disconect the battery and ECM, you can relocate the NATS antena and not have an issue. Well unless there is a load sensitive feature which I havnt seen. Once its all reconected you shouldnt have any problems because the car doesnt know the diffrence. Soooo. key in ashtray, push button start.
EDIT EDIT EDIT: BL-138 shows how to remove it. You know since it has its own connector and in the bundle; looks like you can just strip back the sheathing seperate the wires you nee as far back as you need to, and relocate the antena that way.
Old Oct 27, 2007 | 09:28 PM
  #136
DeusExMaxima
Is there any way to increase the power of the transponder so you can leave the key in your pocket?
Old Oct 27, 2007 | 10:29 PM
  #137
punish_her's Avatar
punish_her
Any easier thing to do, if the reloation works (gonna try when I get back home) is move the NATS Antena to the center console next to the seatbelton the inside on teh colsole. If the transponder ponder is strong enough you can put the key in your right pocket. But thats yet to be tested.
Old Nov 5, 2007 | 05:48 PM
  #138
ni$mo350's Avatar
ni$mo350
I'm looking for the kit but it's not for sale anymore... anyone else know where to pick up the prewired kit?
Old Nov 8, 2007 | 09:39 AM
  #139
ni$mo350's Avatar
ni$mo350
anybody know anywhere i can pick up the kit prewired?
Old Nov 8, 2007 | 11:40 AM
  #140
gringott's Avatar
gringott
KP technologies has put together a kit, I am a beta tester, I should have it any day now, the production should start soon, there is a long thread on it, do a search, KPierson is the my350z.com screen name of the developer.
Here is the webpage of his company, there is a thread on the forums there about it. http://www.kptechnologies.com/
Hope that helps.
