DIY program your remote
Old Jul 14, 2008 | 09:04 PM
deezz's Avatar
deezz
WOW..Very good info.
Old Aug 22, 2008 | 09:40 AM
nasty350's Avatar
nasty350
Originally Posted by idwin
same here...
Old Oct 11, 2008 | 12:31 AM
yogipower's Avatar
yogipower
this is really helpful..thanks!
Old Oct 16, 2008 | 08:18 AM
Mr. Dean's Avatar
Mr. Dean
Does this solve the whole distance problem?
Old Oct 19, 2008 | 11:59 PM
GeturZZZs's Avatar
GeturZZZs
how do you pair your chip in the key to your car
Old Nov 19, 2008 | 09:34 PM
chrisnathan's Avatar
chrisnathan
The original post works for me, great post!!
Old Nov 20, 2008 | 01:37 PM
rsxscrazy's Avatar
rsxscrazy
yep did mine a while back works flawless! took me a second to figure out the flashers just flash once and not suppose to stay on but works!!!
Old Nov 30, 2008 | 06:38 PM
SA Z-boi's Avatar
SA Z-boi
I saw it somewhere that if you put your fob by your head you can unlock your car from a farther distance. Use your body as an antenna
Old Dec 3, 2008 | 07:54 PM
splby's Avatar
splby
this was awesome. thanks OP.
Old Dec 22, 2008 | 02:11 PM
mclovin.too's Avatar
mclovin.too
Thanks for the great info, buying a extra remote off ebay. Will give this a try.
Old Jan 28, 2009 | 03:25 AM
Kokoro's Avatar
Kokoro
i've tried using this method to reprogram my fob that i got from ebay. can anyone please tell me what might be the cause? i've got two key fob from ebay.
Old Feb 17, 2009 | 06:50 PM
my-red-pony's Avatar
my-red-pony
I also bought one from ebay- im sure we went to the same place haha, I had the simular problem- i just changed the battery and boom. dont forget to open and close the door.
+1 thanks for the write up.
Old Apr 3, 2009 | 10:53 AM
JapanLio's Avatar
JapanLio
Originally Posted by hieu
1. Insert key into and remove it from ignition more than 6 times with in 10 seconds. (hazards will flash)
2. Insert key and turn to ACC position.
3. Push any button on remote once. Hazzards will flash.
4. Open and close door.
5. Done. Check operation of other buttons.
Hi,
I am a new Z owner (I will introduce myself in detail in the new member section soon) and I just get a new fob from eBay. What is the trick if I have to reprogram 2 fobs ? I have to re-do the step 3 before the step 4 ? or re-do the whole procedure for each fob ?
Thanks.
Edit: In fact, just use the unlock door button then close again to program another remote control. When the operation is finished, open the doors AND open the driver door. It works perfectly.
Last edited by JapanLio; Apr 3, 2009 at 06:10 PM. Reason: Answer to my own question
Old Aug 5, 2009 | 12:16 PM
ZS14RR's Avatar
ZS14RR
GREAT SUCCESS !!!!! i just did mine and it worked like a charm
thanks op saved me 60 bucks
Old Aug 6, 2009 | 11:18 AM
StewartZ's Avatar
StewartZ
awesome!
Old Aug 22, 2009 | 05:08 AM
kyle22's Avatar
kyle22
this helped me save over 100+ from the stealership...thank you OP!! and i didnt have to buy a new key FOB just changed the battery from the original one.
Old Feb 19, 2010 | 03:03 PM
BJJ Gi Choke's Avatar
BJJ Gi Choke
ttt
Old Feb 20, 2010 | 08:34 PM
  #38
starvinmrvn's Avatar
starvinmrvn
Old thread...yes...BUT I found it very useful today...thanks guys! Remember...insert and remove key semi slowly...I kept doing it to fast and car was not registering it.
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
NFAC
Sep 26, 2015 10:11 PM
Detailed Image
Cleaning & Detailing
Sep 18, 2015 11:43 AM
Detailed Image
Sep 16, 2015 04:56 AM
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
