Install Guide:Bose, Kenwood DNX7100, PAC ROEM-NIS2, 03 cubby painted, cubby monitor
Old Apr 29, 2008 | 08:11 AM
kaminariZ's Avatar
kaminariZ
question, so what if i want to replace the Headunit and put in aftermarket speakers and subwoofer and amplifiers. do i still need the PAC NIS2? Or no? and if i have the stock navi, will it be effected if i put another headunit it?
Old Apr 29, 2008 | 11:25 AM
k1653d's Avatar
k1653d
You would not need the PAC NIS2 if you are going to replace the amp. As far as the stock NAV, I am sure there will be complications there but am not sure what you would need to get it working.
Old Apr 29, 2008 | 11:37 AM
kaminariZ's Avatar
kaminariZ
will i need the metra wiring harness then?
Old Apr 29, 2008 | 06:38 PM
k1653d's Avatar
k1653d
Yes.
Old Apr 29, 2008 | 08:56 PM
Pete's 03SVT's Avatar
Pete's 03SVT
If you change the speakers and add aftermarket amplifiers to run them you do not need the Pac OEM-1 any longer. You only use it to retain the factory amplifiers. The stock nav will still work, but there is some amount of rewiring to get the nav audio to work. There is a thread that explains how to do it.
Old Apr 30, 2008 | 12:19 AM
GSX-R350Z's Avatar
GSX-R350Z
Thanks OP for writing this DIY.
I was wondering what you did with the 'Arm Trigger' wire thats blue and white. I'm installing an Avic-D3 and have no idea where it goes.
Thanks for all your help.
Old Apr 30, 2008 | 07:05 AM
k1653d's Avatar
k1653d
The Avic-D3 does not have a blue/white wire so you dont connect it to anything. So that would make 5 wires from the PAC that are not connected to anything if you are installing a D3.
The Metra harness has almost the same wires that the PAC has except the Metra has the orange/black dimmer and the PAC has the 4 extra speaker wires.
If you look at orbitalpunk wiring picture you will see that he as the blue/white wire 'X' off. That is because there is not another blue/white wire to hook it up to. Be sure to connect both the solid blue ones though.
Old May 18, 2008 | 05:48 AM
_ink's Avatar
_ink
This is the BEST install that i have seen for the Bose units!!
Thankyou soo very much for this!!
Old May 24, 2008 | 01:15 PM
kaspia's Avatar
kaspia
Wow, very informative - Thanks!
This thread will definitely help make my install much easier.
For anyone who is debating whether to paint the cubby lid - Here is my pix that compare the 03 lid to the 07 lid.
Update: The 03 lid color don't match at all and the 2003 have a shine/metallic look.
Old May 24, 2008 | 01:27 PM
haeshik's Avatar
haeshik
Originally Posted by silverstripes
Man that is the best install DIY Ive seen. This deserves a sticky!
+100000 awesome
Old May 25, 2008 | 02:21 PM
adamtaylorpcb's Avatar
adamtaylorpcb
great diy this will come in handy soon
Old May 30, 2008 | 07:10 PM
PrevWon's Avatar
PrevWon
Awesome write-up. Subscribed.
Old Jun 5, 2008 | 01:25 PM
ryanschram's Avatar
ryanschram
thanks for the writeup. I was waiting on somebody to do a cubby screen.
Old Jun 20, 2008 | 12:42 PM
ncparamedic's Avatar
ncparamedic
Prodigal Son
Sorry to bring this one back, but what is the difference, size wise, on the interior of the cubby..i heard the 07 was smaller.
Old Jun 20, 2008 | 05:38 PM
kaspia's Avatar
kaspia
I tried it myself and the 03 Lid is much smaller than the 07 Lid. I am still researching on finding a way to fabricate something to fill in the gaps. So this project is still "pending".
Check out the pics for more detail.
Notice how the colors don't match.
It didn't flush out to the edge
The interior liner didn't flush to the housing
Also when the 03 Lid retracts back -- it will barely clip the Triple gauges housing; making it caught and won't retract without me assisting it.
So now my 03 Lid is just sitting there taunting me. *back to the drawing board
Old Jun 20, 2008 | 05:40 PM
ncparamedic
Prodigal Son
how about mounting the screen in the 07..how much difference is there in the cabinet area?
Old Jun 20, 2008 | 05:43 PM
kaspia's Avatar
kaspia
I don't quite understand your question. Just added another sideview pic of the 03 Lid in the 07 Housing.
Old Jun 24, 2008 | 01:55 AM
  #38
stanleylee's Avatar
stanleylee
Just finsih install a D3 with PAC,
and want to make a correction,
if u have bose system the blue/white wire from the PAC should connected to the D3's blue/white wire, or else it will have no sound, coz the amp wont turn on.
Old Jun 25, 2008 | 07:43 PM
  #39
ncparamedic
Prodigal Son
Sorry, i meant inside the cubby. Is there a difference in the amount of space inside the cubby from the 03 to the 07? Can you mount a 6.95" monitor in the 07 cubby with modification?
Old Aug 22, 2008 | 09:41 AM
  #40
nasty350's Avatar
nasty350
good write up
