2008 Door Panel Removal / Front Speaker Install
Old Aug 19, 2009 | 06:13 PM
bcmtn's Avatar
bcmtn
Nice write up. However I found it much easier to remove the speaker grill, and pop the bottom of the door panel loose and remove/install the speakers through the bottom of the door panel. The bottom screw that holds the speaker bracket is the only tough part because you have to use on open end wrench. I swapped both my fronts out in about 35 minutes.
Old Sep 8, 2009 | 05:46 AM
yogipower's Avatar
yogipower
is this the right one?
http://www.buy.com/retail/product.as...ingid=29792810
now i need to find the place to install mine...
Old Sep 8, 2009 | 01:23 PM
*ICE*'s Avatar
*ICE*
How did you pop out the grille? nevermind... I had the Bose so i have to remove the door panels to do the wiring
Old Sep 8, 2009 | 01:24 PM
*ICE*'s Avatar
*ICE*
i found the same pair brand new on ebay for $50 shipped.
Old Sep 9, 2009 | 06:07 PM
oddjobbb's Avatar
oddjobbb
did you just bypass the tweeters or are you still using them?
Old Sep 9, 2009 | 06:31 PM
*ICE*'s Avatar
*ICE*
I think you should remove the wiring for the OEM Bose tweeters because the Reference 6022si came with tweeter on the speaker. They are 2-way speaker.
Old Nov 22, 2009 | 06:38 PM
usgpru27's Avatar
usgpru27
Has anyone has good results with the Infinity Reference 6032si speakers? Are they the same fit as the install noted? I have a stock head unit and want to keep it that way. Just want a little better speaker. The reviews on the 6032's have better base perfomance than the 6022's?
Thanks for any advice..
Old Nov 24, 2009 | 02:45 AM
jmark's Avatar
jmark
^ In for answer.
Old Nov 24, 2009 | 03:24 AM
*ICE*'s Avatar
*ICE*
i have 6022si in my front and rear and it sound great. Both 6032 and 6022 wont have any good bass because they are 2-ways speakers. 2-ways generally dont have a woofer in them, just tweeter and midrange. If you want a solid, decent bass, just get a single sub in the back and hook it up to the headunit.
Old Nov 24, 2009 | 02:41 PM
usgpru27's Avatar
usgpru27
Ice, Thanks.. Should have same bass as the stock speakers correct?
Old Mar 26, 2010 | 12:21 PM
BJJ Gi Choke's Avatar
BJJ Gi Choke
ttt
Old Feb 5, 2011 | 01:54 PM
sp0811's Avatar
sp0811
Thanks you for this write up. I needed to replace my passenger side window control cover that was badly scratched. This write up made the job a breeze.
Old Aug 3, 2011 | 01:46 PM
whitelightningHR's Avatar
whitelightningHR
Thank you for posting this. It really came in handy for replacing my door speakers.
Old Mar 17, 2012 | 12:51 PM
sportbiketed's Avatar
sportbiketed
My kicker QS 65.2's where a little too big for the brackets so I made an mdf ring and used an epoxy to attach it to the factory bracket.
Old Apr 7, 2012 | 11:50 AM
arbor22's Avatar
arbor22
Great guide! all the info is presented in the perfect way makes is easy to understand. just one question and this may have been asked already and i just over looked it but i just bout a 2004 z will this guide work for that too or will it show me how to do it with minimal differances?
Thanks zack
Old Apr 7, 2012 | 01:49 PM
ChinaClipper's Avatar
ChinaClipper
Minimal differences Zack. The earlier 03-05 cars had a different configuration of arm rests and door grip, so the screw arrangement differs slightly from the writeup, but nothing complex. All else is identical though. Good luck.
Old Jul 3, 2013 | 06:54 AM
ainfante21's Avatar
ainfante21
Thanks a lot man!
Old Jul 3, 2013 | 03:30 PM
  #38
DarkCreep's Avatar
DarkCreep
Why is it so complicated to put speakers on lol.. I dont want to ruin my OE speakers to install my Polks!!
Old Oct 23, 2013 | 10:58 AM
  #39
Killa_Kali's Avatar
Killa_Kali
Thank you, that was very helpful. I was simply just trying to find the first few steps to re-do my door panels.
Old Oct 25, 2013 | 12:53 AM
  #40
NoQuestionZ's Avatar
NoQuestionZ
subscribed to fix my door handle area. Thanks!
