Subwoofer in stock location
Old Apr 23, 2011 | 07:31 PM
  #41
2fasst's Avatar
2fasst
How would you rate the Fat Mat?
Old Apr 23, 2011 | 08:44 PM
  #42
dcains's Avatar
dcains
I've got nothing to compare it to, but if I rap my knuckles on the speaker enclosure it sounds like a solid block of concrete. Last Summer I also used it in my '92 Alfa Spider when I was replacing the carpeting. I did the floor pans and the gearbox tunnel, and it deadened the road noise very well. The best part was that I used two layers on the driver's side floor, to insulate the heat from the headers and cat, and now I can drive in just socks, without burning my right heel on a long drive.
Old Apr 24, 2011 | 04:39 PM
  #43
oddjobbb's Avatar
oddjobbb
Originally Posted by dcains
Here's my setup, which is very similar to "asteffy"s. Great minds think alike
Actually, my pic hosting site is down, so I'll post pics later.
do you recommend deadening the box itself, did it make a difference?
Old Apr 24, 2011 | 09:04 PM
  #44
dcains's Avatar
dcains
I didn't do any comparison, and this is the first time I've ever used the FatMat. But the box is totally dead and airtight, and that's how it should be. As for the FatMat on the metal panels, you can tap on the metal and it really doesn't seem much different before and after. I had a 40 sq. ft. kit, so I just tried to use it up.
Old Jul 29, 2011 | 01:33 PM
  #45
BrainLeash69's Avatar
BrainLeash69
Mine:
- JL Audio 10W3v3-2 10” Subwoofer
- JL Audio 500/1 Class D Monoblock Amplifier (on top)
- JL Audio 4 & 8 Gauge Wire Amplifier Installation Power Kit
Old Jun 29, 2012 | 06:31 AM
  #46
brandon kak's Avatar
brandon kak
going to try to make one next weekend. Any suggestions/ recommendations on what sounded the best? Trying to just mount the sub into the stock location or making a box and sticking it there?
Old Jul 5, 2012 | 02:02 PM
  #47
Collin Lacy's Avatar
Collin Lacy
Holy thread revival. Just wanted to answer his question, even though hes probably already asked it elsewhere. Make a box, its worth the 10 bucks youll spend on wood and glue (more if you use dyna/fat mat.)
Old May 28, 2013 | 12:28 PM
  #48
vicjr24350z's Avatar
vicjr24350z
Does anyone have the dimensions for a good 10" sub box that they made in the stock cubby hole?
Old May 28, 2013 | 02:24 PM
  #49
dcains's Avatar
dcains
Mine, which is pictured above is 18" x 12.5" x 6.5", out of 3/4" MDF. It seems to be the largest size which will fit if you just want to make a box with 90-degree angles. BrainLeash69's box, looks like it has a bit more internal volume, which may be important, depending on the subwoofer you choose. Either way, a sealed enclosure is the only way to go.
Old May 29, 2013 | 05:27 AM
  #50
vicjr24350z
thanks i will probably get started on that this weekend
How does yours sound by the way?
Old May 29, 2013 | 01:34 PM
  #51
dcains's Avatar
dcains
I think it sounds great. It's been installed now for almost 3 years, and I've got no intentions of changing a thing. The HU is a Kenwood, the other speakers are Boston components, and the amps are JL (one 1-channel and one 4-channel).
Old May 30, 2013 | 06:25 PM
  #52
radiivan's Avatar
radiivan
Okay, so i like how both of you guys did it and i am looking to do about the same, i just have a couple of questions, what size cables or what are the references for the cables to hook up the sub to the amp? Also what size amp did you use ? i have a 10" type R. Lastly, how the hell did you guys strip the plastic pieces off of the rear speakers ? thanks a lot.
Old May 30, 2013 | 07:01 PM
  #53
mattleegee's Avatar
mattleegee
very nice.... if i ever tear out the Bose system i will defiantly be doing something similar to put a 10" in
Old May 31, 2013 | 12:31 AM
  #54
dcains's Avatar
dcains
I don't recall the model numbers for my JL amps, but the sub is 250W x1 and the main amp is I think 100W x4. I used two 4 ga. cables from the battery to the amps, the same for the amp grounds to the chassis, and probably 12 or 14 ga. for the speaker wires. More than sufficient for my setup. I'm just listening to music at a reasonable level while driving, or washing/waxing.
The plastic interior panels all just come off the body with gentle pulling, but you have to remove them in the right order. You obviously pull the panels overlapping from the top first, and so on. The only fasteners are the screws around the glove box. There are some threads on this site showing specific instructions for removing the door panels and installing speakers, as well as for the rear panels and speakers. Same for installing the head unit. Search for them, and become familiar with what's involved before getting started.
Old May 31, 2013 | 03:28 AM
  #55
radiivan's Avatar
radiivan
Thanks a lot dcain, very helpful.
Old May 31, 2013 | 03:56 AM
  #56
e30cabrio's Avatar
e30cabrio
I have a Wicked CAS magic box with JL audio 10W3V3 for sale.
https://my350z.com/forum/audio-video...e-sub-box.html
Old Jan 25, 2014 | 05:21 PM
  #57
soldierchon's Avatar
soldierchon
how bad does it sound if i just put an alpine type R in the original stock position?
Old Jan 26, 2014 | 12:45 PM
  #58
mnd7775's Avatar
mnd7775
Does anyone have the dimensions of the space available? Or can I measure the glove compartment and design from there? Are the spaces similar in dimensions?
Thanks.
Old Jan 26, 2014 | 01:07 PM
  #59
Dan Garcia's Avatar
Dan Garcia
Default alpine sub
Not bad at all, I got one in the original behind the drivers seat stock location.
Old Apr 8, 2014 | 07:54 AM
  #60
ohmicide's Avatar
ohmicide
did you use dynamat or build a box?
