Moving Nav Input Part II (pics)
Old May 29, 2006 | 05:22 PM
JasonZ-YA's Avatar
JasonZ-YA
Default Moving Nav Input Part II (pics)
THIS POST COMES FROM RICARDEW. I JUSTADDED PICS. ITS A GREAT MOD.....
THANKS RICARDEW
ORIGINAL POST.
Moving NAV input PART II
I did a mod that allows moving NAV input. It'll work on a coupe. It works on a roadster but creates a fault code (I have a roadster). The speed signal to the NAV control unit comes from the unified meter. I interrupted the signal coming out of the unified meter and attached a switch. When moving, if i throw the switch (break the circuit), the NCU thinks I stopped and allows full input. When I throw the switch again (close the circuit) the NAV picks up my location and speed and off we go.
I chose to after the wire up front from the unified meter because it's easier to get to and that is where it has to end up. A microswitch under the a/c controls would be ideal and it's all right there (the wires from the a/c controls run the the unified meter aka the a/c amplifier/unified meter)
There is a problem with the roadster though. The speed signal splits and goes to the soft top control unit and the passenger seat control unit. Both of these are only on the roadster and keep the top from operating when the car is moving. I didn't think that was a big deal as in the 10 years I've owned convertables I have yet to have the desire to operate the top while moving! Tops are expensive. Turns out that in the rodster, the soft top control unit gets 2 speed inputs from the unified meter. When one is interrupted it generates a fault code, the soft top warning light flashes and the top won't operate. Turn the car off and on again and it all goes away and the top operates. I've been trying to avoid pulling apart the big long panel in the back. It looks like it has a zillion clips! but that looks like tomorrow's project.
Here's what I did today for any coupe owners that would like to do it.
**1. Remove MT boot - just pry up from the back with a taped flat screwdriver, or grab the back of the silver ring and pull up.
**2. There is a ribbon wire from the a/c controls to the unified meter (you can't miss it, it sits below the head unit and is a white rectangular thing). Remove the 2 screws that hold the unified meter in place.
**3. Free up the harness a bit so that you can move the unified meter out a bit.
**4. There are 3 connectors in the back of the unified meter. Remove the middle one. (there is a locking tab that you depress and pull off the connector or push it off with a screwdriver.
**5. The wire with the speed signal (34) is white with a green stripe running longitudinally. When you look at the connector it is on the bottom row, third from the right. (( MINE WAS 2ND FROM RIGHT, TOURING MODEL I GUESS))
**6. Free up the wire (unwrap some of the black electrical tape like stuff) and cut it. I used telephone wire connectors from radio shack to connect a wire to each of the cut ends. You don't have to strip any wire, just place the 2 ends to be spliced and clamp down on the connecter with a pair of pliers.
**7. Attach a switch to the 2 wires.
sorry I was away from home and didn't have my digital camera but can get pics of it.
I HOPE EVERYONE LIKES IT.
THANKS,
JASON.
PS THANKS RICARDEW.
rich
Attached Thumbnails Moving Nav Input Part II (pics)-1.jpg   Moving Nav Input Part II (pics)-2.jpg   Moving Nav Input Part II (pics)-3.jpg   Moving Nav Input Part II (pics)-4.jpg   Moving Nav Input Part II (pics)-5.jpg
Old May 29, 2006 | 05:32 PM
zracin's Avatar
zracin
why would you not just leave the wires taped up and break the line altogether. Is it neccessary to put a switch in?
Old May 29, 2006 | 05:58 PM
JasonZ-YA's Avatar
JasonZ-YA
yes, you need a switch b/c the nav wont follow if its always off. in off mode u can input an address. then when your back at nav map screen u need to switch "on" inorder for nav to track. off thinks u stopped a block back!
-J
Old May 29, 2006 | 09:51 PM
zracin's Avatar
zracin
ahhh i got it thanks
Old May 30, 2006 | 04:50 AM
JasonZ-YA's Avatar
JasonZ-YA
cool. Ya. I love the mod. its works great and now my passenger can input addresses while im driving.
- Jason
Old May 30, 2006 | 07:21 AM
Nucleus's Avatar
Nucleus
Yeah I did this mod also. Same results on my automatic Z.
Old May 30, 2006 | 07:32 AM
JasonZ-YA's Avatar
JasonZ-YA
Nucleus, let me see your switch location? pics?
Old May 30, 2006 | 03:05 PM
SunsetZ33's Avatar
SunsetZ33
Sweet! I've gotta do this. It's so aggrivating to have to stop to enter an address into the NAV!!!
Thanks for the info
Old May 30, 2006 | 06:59 PM
Nucleus's Avatar
Nucleus
I didnt install the switch yet. I did the mod but just have the switch hanging by my knee. I like the coin tray idea This way I can hide it from the dealer.
Old May 31, 2006 | 03:20 PM
JasonZ-YA's Avatar
JasonZ-YA
yup, i like keeping it tucked away where no one can see. especially the dealer.
- j
Old Dec 28, 2007 | 09:03 PM
onedirtyz's Avatar
onedirtyz
my car is dirty
omg this seem so simple.. i have to do this........or rather, get someone to do this for me. i <3 you.
Old Apr 6, 2009 | 08:31 PM
power2rice's Avatar
power2rice
FINALLY! Someone that figured out the CORRECT VSS wire. IT'S NOT THE WHITE ONE. It's the white with GREEN strip like JasonZ-YA says. Everywhere I keep reading that it's the white wire which is WRONG. Anyhow, here is my pics following JasonZ-YA instructions.
Old Apr 14, 2009 | 12:06 PM
JasonZ-YA's Avatar
JasonZ-YA
sweet! looks good..........so do you have two screens in your car? oem nav and a double din?
-J
Old Apr 24, 2009 | 02:36 PM
power2rice's Avatar
power2rice
Just one screen for now. I'm running an Alpine single din and making use of the lower compartment for my ipod and miscellaneous things.
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
_bit
Oct 2, 2015 07:49 AM
