Fitting the Nizmo rear spoiler
When fitting the Nizmo rear spoiler make sure it is right to the very edge of the boot/trunk lid. If it is only a few mms off the edge the wing tips touch the body work when you go over bumps - producing a perplexing noise every now and then.
CAR2
Is this a genuine Nismo spoiler? mine's install accoring to the Nismo template they included with the wing, it's a good 1-2mm from the edge and it's not causing any problems, plus it has foam rubber under the tips (provided by Nismo).
David
David
Originally posted by CAR2
Spoiler Shop WA ph 0893171988 if you are interested.
I just ordered a set of Nismo side skirts from Daniel! Thanks for your info from the previous time!!! Should be able to get those parts early to mid next week!
cheers,
richie
Good - they are very nice people - they try harder than most - I'm very picky and they fix all my little problems. i want that front spoiler - still trying to work out where to get it.
which front spoiler are you refering to? you meant my veilside one? I think spoilership should be able to get one for ya soon!
cheers,
richie
Yes the Veilside one. I have'nt asked the Spoiler Shop yet.
cheers,
richie
I'll post my expert answer (ie I've never seen a Nismo kit in the flesh). The stock Track spoiler is removed and not reused. The new spoiler uses the existing mounting holes and 2 new holes. Just paint the edges of the new holes with paint if you're worried. Spoilers are usually sealed down with tape so it's highly unlikely any moisture could reach the holes to cause a rust problem.
Someone correct me if I'm wrong.
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
