Z Hitch Prototype
Old Aug 15, 2006 | 12:27 PM
  #161
roark's Avatar
roark
I use Hoppy P/N 46255 - Completely isolates tow vehicle from trailer malfunctions. Power is taken directly from the battery.
The Nissan TSB covering wiring of the 350Z and Altima require the use of this style converter. There is no Nissan part.
Since these draw (practically) no current from the existing wiring (just read the voltage level) they are suitable for the 2006s LED Tail lamp assemblies.
Only downside is that you have to feed the source power wire all the way back to the battery, which takes some time to fish along the driver's side interior and through the firewall.
Originally Posted by PaulN
I've seen references to the Hoppy converters and something from Nissan. Can someone post the respective part numbers of these converters?
Also, if anyone's done this with a 2006 Z, I'd like to hear of any gotchas waiting for me.
Thanks,
Paul
Old Aug 15, 2006 | 01:04 PM
  #162
PDX_Racer's Avatar
PDX_Racer
Why go down the driver's side? I ran mine down the passenger side, and other than getting the wire over the "B pillar box" (where the gas tank and storage box are) it was really very easy to run the wire directly from the battery to the back of the car.
Just make sure that you have some cord molding to protect that 12V from contacting ground!
Old Aug 15, 2006 | 01:11 PM
  #163
commasense's Avatar
commasense
Jim,
Did you get my PM about the heavy-duty hitch you designed? I've realized that using that with a hitch-mounted cargo carrier like this one would be a lot more convenient (and cost-effective) for me than a trailer, since I don't have a good place to store a trailer.
Considering the weak interest recently in the trailer hitch, it also might be of interest to other guys here who are in the same situation. As I mentioned in my last PM, I'd be happy to be your guinea pig to refine the frame hitch.
But if you're not interested in doing the development on it yourself, would you consider selling me your plans so I could find a fabricator to make one for my own use? (I'm not interested in going into the business of making them for others.)
Please e-mail me at editor (at) LFexaminer.com.
Thanks.
Old Aug 16, 2006 | 07:59 AM
  #164
roark's Avatar
roark
I meant passenger side. I've gotta stop those binge drunk posts.... Friends don't let friends drink and type.
Old Aug 16, 2006 | 09:33 AM
  #165
PaulN's Avatar
PaulN
Default Gone (wire) Fishin'
Thanks to you both! Yeah, I bet the conclusion of fishing the wire to the battery will involve beer!
Paul
Old Aug 16, 2006 | 06:33 PM
  #166
PDX_Racer's Avatar
PDX_Racer
Took me about an hour or so to run the wire from the battery to the tire changing tools.
Old Aug 19, 2006 | 07:28 PM
  #167
BlackWidow87's Avatar
BlackWidow87
So can anybody verify if
a) this thing is still selling?
b) it can tow a bike 350 lbs? on a 4x8 to 5x8 trailer?
thanks..
PS: What's the maximum the lowest one can tow?
Old Aug 19, 2006 | 10:47 PM
  #168
PDX_Racer's Avatar
PDX_Racer
My tire trailer is 440 lbs total weight (trailer, tools, tires).
Old Aug 20, 2006 | 11:22 AM
  #169
mich's Avatar
mich
thanks..
there is a group buy going, pending we can get enough people.
i believe due to his schedule, fabrication will not begin till november.
sign up!
https://my350z.com/forum/showthread....81#post2474681
Old Sep 25, 2006 | 05:18 AM
  #170
so350z's Avatar
so350z
whats the most a 350 can pull. a jet ski? 1or 2?
Old Nov 6, 2006 | 11:31 AM
  #171
daveh's Avatar
daveh
Hope it's ok to post this here but I will be selling my hitch that I bought in the original group buy. PM me if interested.
Old Nov 9, 2006 | 08:45 PM
  #172
daveh's Avatar
daveh
I'm no longer going to sell this hitch.
I brought the Z to a local custom hitch installer this week because I felt like I wanted a sturdier solution. He said that when he took off the rear bumper shell he saw that the aluminum bumper rail that the hitch was attached to was about to fail. I'm pretty lucky I brought it into him when I did as I probably would have lost my trailer this weekend if I used the hitch.
My new hitch is very professional. It attaches to the frame via bolts and welds. The reciever is flush with the bumper and comes out through a small cutout at the bottom of the bumper.
At any rate, I'm thinking that this hitch is best suited for bicycle racks but not long distance trailering.
Be safe.
Dave
Old Nov 9, 2006 | 09:04 PM
  #173
BlackWidow87
Be safe.
Dave
That's why i opted to go with the Uhaul hitch over the this private group buy hitch..
Old Nov 10, 2006 | 07:21 PM
  #174
DmanG281's Avatar
DmanG281
Be safe.
Dave
Can you be more specific about what on the bumper was about to fail. I've been rear-ended with the hitch on and the bumper was fine.
Old Nov 10, 2006 | 08:31 PM
  #175
PDX_Racer's Avatar
PDX_Racer
Probably the reinforcement brackets.
I just got a pair seam-welded, and they're now on my car.
Old Nov 11, 2006 | 07:23 AM
  #176
DmanG281's Avatar
DmanG281
I welded the crap out of those brackets when I installed the hitch.
Old Nov 12, 2006 | 07:01 PM
  #177
daveh's Avatar
daveh
I also had the brackets seam welded when I did the original install. This is not where mine cracked. Mine cracked where the aluminum bumper bolts into the car. I am towing the cheapie harbor freight trailer which I'm assuming weighs less than 400lbs fully loaded. I've got the weight pretty evenly distributed so the tongue weight is minimal.
As for the U-haul hitch, it's basically the same as this one.
Old Nov 12, 2006 | 07:19 PM
  #178
PDX_Racer's Avatar
PDX_Racer
Huh?
The hitch "sandwiches" the bumper reinforcement, which mounts to the bumper reinforcement brackets, which mount to the unibody.
So are you saying that the bumper reinforcement itself cracked?
Old Nov 12, 2006 | 07:38 PM
  #179
daveh's Avatar
daveh
Huh?
Ok, you made curious so I just got dirty to take a pic. My crack happened where the bumper bracket mounts to the car. You can see in the attached picture that the hitch guy welded it for me (on the very right). You can also see the orig welds in the bracket that I had my local muffler shop last year before installation.
Old Nov 12, 2006 | 07:44 PM
  #180
daveh's Avatar
daveh
Here's a better shot. It is looking towards the rear of the car.
