DOT R tire choices-which brands do you prefer and why
Old Mar 24, 2005 | 02:53 PM
Eagle1's Avatar
Eagle1
Default DOT R tire choices-which brands do you prefer and why
Gents:
I have been running the Toyo RA-1 on 18" Nismo wheels, and been very pleased with them. However, I might have an opportunity to run the Dunlop Sport Race tires at a good deal. Have any of you experience with this tire, and if so, what are your thoughts of how it stacks up against the other competition choices we have available (Hoosier/Michelin/Pirelli)?
Old Mar 24, 2005 | 03:51 PM
christoc's Avatar
christoc
Are you looking for autocross or track use?
Old Mar 24, 2005 | 04:23 PM
zillinois's Avatar
zillinois
I'll have a review of the Pirelli PZero Corsa in about 4 weeks.
Old Mar 24, 2005 | 04:39 PM
Eagle1's Avatar
Eagle1
I apologize. Road course use, in the dry.
Old Mar 24, 2005 | 11:56 PM
GY-Z's Avatar
GY-Z
i dont see anyone using A048, mind asking why?
Old Mar 25, 2005 | 10:25 AM
AznIceRckt's Avatar
AznIceRckt
i believe a048's only come in 225, 265, and 285 sizes. mainly porsche 911 race tires.
do you guys run matched, or staggerred? say a 245/245, or 245/275. i'm only pushing 250ish whp, so i dont believe i need anything bigger then 245 rear in r-compound. thinking 245 ra1's all around.
phil
Old Mar 25, 2005 | 10:54 AM
bwzabodyn's Avatar
bwzabodyn
If I can't sell my stock 17" wheels, I'm going to sell the tires and put R-compounds on them - 245/45 front, 255/45 rear - probably whatever I can get the cheapest in those sizes since ANY R-compound will be better in the dry than my 19" KDWs (and a heck of a lot cheaper to replace)
Old Mar 26, 2005 | 05:02 PM
mpowers's Avatar
mpowers
I just burned a set up today at Roebling Road, 255's, happy with the performance, very little over heating with 140 minutes of track time (20 min sessions). May have one more day left in them. Overall good wear & grip
Old Mar 27, 2005 | 08:24 PM
stumpmj's Avatar
stumpmj
I've been running 275/40-17 Nitto 555R2's all around. They're cheap ($160 each, heat cycled), sticky (at least compared to street tires), don't overheat, and last a long time. I've gotten about 12 20 minute sessions on them and they're just now down to 2/32 tread depth (I even drive them to and from events, a total of about 2000 street miles). I keep thinking I should try something else but its hard to when I've had such good luck with these.
Old Mar 28, 2005 | 02:49 PM
dirtroad's Avatar
dirtroad
I've got a set of stock 17" rims I want to use for track and autocross events. I'm looking at getting the Toyo RA-1s, what sizes should I use?
Old Mar 28, 2005 | 08:38 PM
amolaver's Avatar
amolaver
my current list of possibilities looks like this:
toyo ra-1
www.toyo.com
235/40-17 front
255/40-17 rear
avon tech r
sizes no good - 225 or 275 width for 17's
kumho v700 (aggressive street looking)
235/40-17 front $161/ea shaved
245/40-17 rear $161/ea
kumho v710 (slick looking)
245/45-17 all around $179/ea
kumho v700 victoracer
245/45-17 $166 shaved
255/40-17 $173 shaved
i'm looking to get a second set of oem 17" rears to run up front, although if i can't find any cheap, i may try and run the ra-1's 235 up front. so far, the v700 victoracer may be the best fit for what i want, but i'm not familiar with their grip level. i'm ideally looking for a 10mm stagger f/r. i think the car pushes a little bit with my 225/245 f/r azenis setup, but not enough to run matched f/r.
at this point, i'd like to try the 10mm stagger and get as much negative camber in the front as possible. what are the limits? w/o going to upper control arms, how much can the factory pieces allow (given stock suspension)?
ahm
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
