Question for track guys re: bump steer/shimmy shimmy shake
Old Jun 7, 2005 | 03:41 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Default Question for track guys re: bump steer/shimmy shimmy shake
Now that I am using a grippier street tire, and have had the car aligned, etc, I've noticed what I can only describe as a "shimmy" in the steering wheel immediately preeceding a bump in the road. It varies in intesity with the bump itself, though it never gets incredibly violent. I've never experienced this before, so am unsure exactly how to title it to you guys. From my reading up on a few different sites, it seems bump steer would be the applicable term, but I could be wrong. I do not hear any atypical clunks or noises (having coilovers and stiff walled tires, I have grown somewhat accustomed to these noises, particularly at low speeds). The only odd thing I find re: bump steer is the car has a great alignment on it right now, with about -2 camber, a tinge of toe out and castor that is well within spec.
Tomorrow is oil change time so we are going to give everything up front a once over...but it would help to know where to start.
Relative mods: Cusco sway, Cusco coilovers, Cusco a arms, S03's on Work Emotions (18x8.5 +30 with a 5mm spacer) and 245/40/18 S03's at 34 psi.
Thanks in advance!
adam
Old Jun 7, 2005 | 08:27 PM
Kolia's Avatar
Kolia
I just reallized I have no idea what the standard offset is on our car...
Here is a hint so you can orient your research on your issue: Scrub Radius
The Scrub Radius is the distance between the center of your tire contact patch on the ground and the extention of the axis of rotation around the steering axis. The longer this is, the longer the lever that pushes against the steering wheel whenever you hit a bump.
Wider tires usually increase that (moves the contact patch outboard), your offset might have changed also. More grip and stiffer sidewall will also transmit more of these forces. Lowered suspensions might affect your castor (which normaly works with you to keep the car going straight). Less castor means a steering more susceptible to road irregularities.
It's "normal" in that it's not a problem. It might keep you on your toes !
Old Jun 7, 2005 | 09:05 PM
daveh's Avatar
daveh
It's probably due to tires and offsets. I notice this with my beefy race tires up front. Returns to normal with my stock tires.
Old Jun 8, 2005 | 03:10 AM
FritzMan's Avatar
FritzMan
If we're talking about the same thing (steering wheel feedback when hitting a bump) I found it got worse the stiffer the front bar was set. Like you I wasn't sure if it was bump steer but the term would match the effect nicely.
It's brutal with the Hotchkis full stiff, tollerable when at medium, and not an issue when the stock bar is used.
Old Jun 8, 2005 | 04:03 AM
John's Avatar
John
I'm thinking the same thing. Since a stiffer bar "lessens" the independence of each of the wheels, when you hit a bump on one side, it's going to have an effect on the opposite side.
Old Jun 8, 2005 | 05:10 AM
EnthuZ's Avatar
EnthuZ
I had a similar "Bump Steer" issue with my Kumho MX 255/45 on 27mm offset 9" rims. I thought that the 30 mm increase in width & the 3 mm increase in scrub radius was causing it. BUT NO!! I recently switched to Falken RT-615's, size 255/40 17, and the bump issue has disappeared! I'm guessing that the more rounded outer edges of the tread have contributed to the improvement.
Old Jun 8, 2005 | 05:33 PM
Z1 Performance
Former Sponsor
I "think" we figured it out today - noticed when turning the wheel from a dead stop I heard a little clunk...put the car up in the air, and viola...bad inner tie rod end. I am praying the dealer has it in stock tomorrow and all should be right with the world
Old Jun 9, 2005 | 09:57 AM
benzz280's Avatar
benzz280
off topic but what kind of 5mm spacers are you using? Are they strong enough for the track? Are you selling them? thanks!
Old Jun 9, 2005 | 10:05 AM
Z1 Performance
Former Sponsor
just generic 5mm ones...does not need to be anything special for that small of a spacer. If it were larger, hubcentric would be the way to go.
not something we sell..any tire place will have them
These will be eliminated tomorrow anyway as I just got new front wheels with a lower offset...the spacers were for purely cosmetic reasons
etkms
Jun 19, 2022 06:30 PM
_koubie_
Sep 20, 2015 06:34 PM
ddegrande21
Sep 6, 2015 11:15 AM
