Race seat question
If you buy race seats and harness you also have to buy roll cage to strap the harness to right?
I'm thinking about Corbeau FX1 Pro + 4 point belt but to use the belt I have to have a roll cage?
you need a steel bar behind the seat to strap the harness right?
roll cage i saw is like 500 dollars
steel bar would be not cost effective if it only serves one purpose rather than a roll cage that can serve both safety and seat harness thing...
right?
right?
Finding anchor points for the harness is not the most critical point.
Making sure the roof doesn't collapse in a roll and snap your neck is the real challenge. With a harness, you can't bend over to get out of the way of the roof.
This is why you need at least a roll bar.
rigid bucket seats + harness + roll/flip - rollcage = goodluck being fed through a straw
"Technically required" makes sense only if you consider that the risk of a serious head and neck injury actually go WAY UP if you use just a race seat and harness. As Kolia has stated, having a 4-7 point harness does you no good unless you've got a least a main hoop for safety. So you might consider a roll BAR rather than a cage for street use. There's been discussion on other threads (with pics) about this, so try a search...
If you just do auto-X.. i think you'll be ok with just race seats, harneses, and a harness bar.. since the chance of flipping over is very slim.
when you do HPDEs, there are dips/gravel when you go off course,.. AND other drivers that *might* hit you, causing you to flip. hence the roll bar suggestion.
it's always best to do it right the first time and not half azz it.
Originally Posted by del105
I find that a harness in a Z is not needed get a g-lock on the seatbelt or buy a rollcage.
www.cglock.comIf you are going to go the harnesses route, its like a never ending cycle for safety, but it is WELL worth it if you HPDE. If you get harnesses, you should get a roll bar or cage. If you get a roll bar/cage and you still drive on the street, you need good roll bar padding. If you have harnesses, race seats, roll bar/cage, etc. The factory airbags could pose more of a threat than anything, so I would suggest taking them out. Then of course there is the HANS devise which tops off the whole package. If the Hans devise is too pricey, at least get a neck brace from either Simpson, G-Force, RCI, etc. I would also suggest fireproof clothing and at least attaching a fire extinguisher somewhere in your car that is easily accessable in case your car is on fire and you are unconcious. Although it is not likely that you will ever use these things, all it takes is one incident. Right now I am in the middle of all of this safety stuff and it gets costly. But if your life is worth it to you, this is a MUST if you do HPDE type or Open Road racing.
Just for lateral support speaking...
our stock seats are pretty good right?
I've never sat in a racing bucket like Sparco EVO2 or something...
but comparing it with other stock seats like S2000 its pretty good right?
Sorry im noob
Sorry im noob
Sorry im noob
Sorry im noob
This bar would serve as a good harness bar and roll bar for a good price... just as long as you're not going to get too serious into road racing.
http://www.kirkracing.com/index.cfm?...Yes&PhotoID=65
its like 450 dollars for the Z + installation lol... not bad but if I do want to have a 6 point cage it can be upgraded or do i have to buy a new one ?
I have the Kirk bar and I like it. Installation was pretty easy so I don't really think you need to take it to a shop. If you want, why don't you have a shop turn the Kirk 4 point into a 6 point?
Originally Posted by Nano
I recall cusco had bolt-in 6 point and 7 point bars, possible?
Actually the Kirk 4 point is only $350 and the full bolt in cage is $660. It also doesnt look very hard to install the cage.
