C-West S2k sets new FR record at Buttonwillow with stock JDM Motor
Old Dec 13, 2005 | 09:32 AM
pope's Avatar
pope
yeah, im not in the AF anymore so i took it off for the vegas username.
Old Dec 13, 2005 | 10:10 AM
homiusang's Avatar
homiusang
Here's the spec of the Cobalt from GM's website
Chevy Cobalt SS Supercharged Time Attack Unlimited Specifications
Body/chassis structure Unibody
Body material Two sided galvanized steel; carbon fiber doors, hood, decklid, rear wing, front and side rocker extensions, roof
Chassis material Two sided galvanized steel, carbon fiber roof
Suspension (Front) Macpherson strut, no front bar, increased spring rates, Ohlins double adjustable struts
Suspension (Rear) Twisting beam with adjustable sway bar, increased spring rate, Ohlins double adjustable shocks
Wheels 9.5 x 17
Tire size (Front) 245/40R17
Tire size (Rear) Same as front
Tire brand Hoosier DOT
Brakes 310 x 26 - vented discs front
270 x 14 - solid discs rear
Powertrain
Engine Stage 2+ equipped 2.0L ECOTEC LSJ with Eaton M-62 Gen 5 Hybrid supercharger , larger injectors and 77.9 mm pulley
Engine displacement (cu. in / cc) 122 / 2000
Horsepower maximum (hp) 283 @ 6840 rpm
380 @ 6700 rpm with nitrous
Torque maximum (lb.-ft.) 243 @ 4200 rpm
387 @ 3500 rpm with nitrous
Transmission F35 5-speed manual with 4.45 final drive
Dimensions
Height (inches) 55.7
Length (inches) 180.3
Width (inches) 67.9
Wheelbase (inches) 103.3
Track Front / rear (inches) 57.1 / 58.1 nominal
Weight (lbs / kg) 2350 / 1066
Old Dec 13, 2005 | 10:19 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
They used nitrous!??
Old Dec 13, 2005 | 11:15 AM
pope's Avatar
pope
it doesnt say in their write up. they only make 285 hp without it though.
Old Dec 13, 2005 | 12:17 PM
DmanG281's Avatar
DmanG281
I'm going to put nitrous on my lawn mower and tell everybody it has 500hp.
Old Dec 13, 2005 | 12:18 PM
pope's Avatar
pope
good for you
Old Dec 13, 2005 | 12:20 PM
bluesaint's Avatar
bluesaint
ya they were. its mentioned on their website under the specs.
Old Dec 13, 2005 | 12:21 PM
SinCity350Z
Track Whore
I have never heard of a track car using nitrous. I wonder how many laps it takes for the bottle to run out?
Old Dec 13, 2005 | 12:23 PM
bluesaint's Avatar
bluesaint
remember it's time attack sessions, so they can go back to the docks and swap bottles if needed most of the cars in these TA will not last endurance races or be safe for that type of event.
Old Dec 13, 2005 | 12:24 PM
bluesaint's Avatar
bluesaint
btw.. some pix of the time attack
http://forums.superstreetonline.com/...ry.php?cat=548
Old Dec 13, 2005 | 12:25 PM
SinCity350Z
Track Whore
Good point. I don't know why I didn't remember that.
Old Dec 13, 2005 | 03:20 PM
Scott Webb's Avatar
Scott Webb
You might be surprised how many road racing cars have used nitrous, albeit hidden and illegally. Can you say "push to pass"?!
Old Dec 13, 2005 | 03:44 PM
GY-Z's Avatar
GY-Z
Perhaps even more impressive is that Chevy Cobalt's time...
thats what happens when you got bank roll from a factory team
Old Dec 13, 2005 | 04:01 PM
pope's Avatar
pope
all of those cars are pretty high budget cars. i wouldnt say that the cobalt has much more than any of the other cars as far as money wise
Old Dec 13, 2005 | 04:10 PM
SinCity350Z
Track Whore
The pro drivers don't hurt either.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
SharX59
Sep 27, 2015 09:23 AM
