Solution for leaking differential breather
Old Mar 13, 2006 | 03:14 PM
racin's Avatar
racin
So how is the fluid going to get back to the diff? It's great that you aren't letting it puke out onto the track, but the diff will still run low/dry while the catch tank is full of fluid.
Old Mar 13, 2006 | 04:01 PM
EnthuZ's Avatar
EnthuZ
The design purpose wasn't to recycle the fluid. It was simply to provide a means of catching the fluid that SOME people are leaking. I'm talking about a tea spoon worth of fluid loss over a weekend of tracking. In my humble opinion, I do not think this minute volume of fluid loss would have a detrimental effect on the rear axel gears. The volume of the catch tank should be way more than any normal track junkie will ever need. If I ever see fluid loss greater than this, I'll look at another solution. Adding a splash of diff fluid isn't THAT difficult.
BTW, Nick, have you ever measured your diff fluid temps?
Old Mar 13, 2006 | 04:16 PM
zillinois's Avatar
zillinois
Originally Posted by EnthuZ
Last week I installed a catch tank "JUST LIKE MINE" in Jacks 350Z. I moved the mounting points a bit for ease of tapping the crossmember. He decided not to go with his aeroquip fittings, and just let me do my thing. His install is 100% complete. Blue LockTited to 48 in-lbs. The OEM rubber hose is already at a perfect length. It's attachment just clears the filter. And, the filter has enough clearance to be changed without removing the tank. He is currently running his OEM muffler with it's built in air deflector, and it cleared without any issues.
Getting ready to do it again on StaticCling's Z this weekend. ALL the kinks have been worked out!
Some new pics:
Looks pimp. Will you be down at Jack's next weekend for StaticCling's install?? I'll be there with the new ride putting together the new ride! BTW, I bought another red 350!! F350 that is. ;-)
Old Mar 13, 2006 | 06:14 PM
StaticCling's Avatar
StaticCling
Sweet, can't wait for the install. Mine is the super sexy titanium HKS oil catch can. I might also have the Quaife installed by then as well.
For me, it did not lose all that much fluid. However it started to smell terrible as it just sat in that crossmember. This should provide an eaiser way to dispose/contain the runout.
I heard that you were getting a new ride Zillinois. I wonder if it could tow perhaps a Z and a Diasio at the same time . See you this weekend.
Old Mar 13, 2006 | 06:47 PM
03Z33's Avatar
03Z33
You guys are just over filliling your diffs... when the fluid starts dripping from the fill hole, let all of the excess come out (about 1-2 min) before plugging it up. You'll notice much less (if any) excess runoff.
Old Mar 13, 2006 | 07:06 PM
zillinois's Avatar
zillinois
It has got the capacity, now can we fit a D and a Z in my 28' footer??
03Z33, these guys are cooking their differentials from repeated 20/30 minute sessions hot lapping. Heavily stressed differentials spew oil and the catch can is a good way to be polite to other drivers by keeping your fluids off the track.
Old Mar 13, 2006 | 08:16 PM
racin's Avatar
racin
I have not measured the temps, though I'm embarrassed to say that. I'm told the NISMO rear cover is good for a temp drop of about 30 degrees (F).
I had to re-fill the diff after every racing weekend due to all the fluid loss. This year, the whole system is being upgraded to include a cooler and electric pump, as well as the NISMO finned cover and a catch can. Transmission is being cooled as well. Unfortunately, progress on the car has been remarkably slow due to lack of time to dedicate to it.
Old Mar 13, 2006 | 09:41 PM
EnthuZ's Avatar
EnthuZ
Yes, I'll be going to BFJ's this Saturday to install StaticCling's catch tank. Hope he will help me install my Stillen engine torque dampener. Geoff, congrats on the BFT!
03Z33, trust me, we are NOT overfilling our diffs! Overdriving, absolutely!
Old Mar 14, 2006 | 08:37 AM
daveh's Avatar
daveh
If we were overfilling them, than we would only be loosing fluid on the first session. I continually watch my fluid **** out after all of my sessions throughout a weekend. At the end of the weekend, my diff is clunky and loud and I have to fill her up before my trip home. Strange thing is that I can get her to leak after what I consider to be an easy session. And it seems to be be worse on high speed tracks.
Old Mar 14, 2006 | 12:28 PM
03Z33's Avatar
03Z33
You must all be running stock viscous lsd's? You may want to upgrade to a clutch style lsd, and the Nissan Motorsports finned cover doesn't hurt either...
Old Mar 14, 2006 | 12:44 PM
daveh's Avatar
daveh
Ha, I wish. I have a nismo lsd and finned diff cover.
Old Mar 14, 2006 | 06:50 PM
EnthuZ's Avatar
EnthuZ
Ditto! Plus I'm running a 350EVO 3.9. And I've not run R compounds.......yet!
Old Mar 14, 2006 | 08:06 PM
Redfoot's Avatar
Redfoot
+1 +Rs & I let the diff drip for 5 minutes and it still pukes it out..... It didn't spit fluid until I changed out the stock VLSD.
Old Mar 14, 2006 | 08:35 PM
03Z33's Avatar
03Z33
That's weird, because I beat my car to a pulp, full throttle drifting with my diff set to 2-way full lock and not moving so very little airflow... I don't get any overflow as long as I use the good fluid (Kaaz) and don't over fill it...
I ran a track event at buttonwillow (full track) where my brembos cooked a brand new set of Hawk blue pads in two sessions, and I never had any diff fluid leak out... just surprised that's all
Old Mar 14, 2006 | 09:29 PM
EVO-8-Nate's Avatar
EVO-8-Nate
Nice clean install! I like it a lot!
-Nate
Old Mar 19, 2006 | 05:50 PM
EnthuZ's Avatar
EnthuZ
Thanks Nate!
I recently installed #3. Not nearly as cool as the 1st 2 CandyApple Raspberry Red oil tanks, but the bronze look works with his Stillen exhaust! But it is a HKS, with a sticker, so not sure which will be faster.....racing red. or stikered? Forgot the formula........
Found out that the volume full tube is visible through the wheels!
Attached Thumbnails Solution for leaking differential breather-ba-s-hks-diff-catch-tank-6.jpg   Solution for leaking differential breather-ba-s-hks-diff-catch-tank-7.jpg   Solution for leaking differential breather-ba-s-hks-diff-catch-tank-9.jpg
Old Mar 19, 2006 | 06:07 PM
zillinois's Avatar
zillinois
Thanks Nate!
Another sweet install Bruce! You are really getting amazing at install on these. I feel left out without a catch can. Maybe I could put one on the Diasio. Next weekend we will actually do something on your car!!
Old Mar 19, 2006 | 06:13 PM
  #38
StaticCling
I could not be happier with the install/fitment. Yes I received #3, and the diff leakage issue should now be solved. I was getting a minor amount of fluid on hot track days (>=90 degrees) with the stock VLSD and stock (non-nismo) diff cover. This year I have the nismo-diff cover and the catch can.
Next up, front brake cooling.
Old Mar 19, 2006 | 06:18 PM
  #39
daveh's Avatar
daveh
these are way to high class
I just put a 3' hose in place of the 1' hose that the brilliant nissan engineers ran from the diff. We'll see if that will keep me from pissing fluid into the chassis. I'm hoping it flows back into the diff when things cool down. I'll put a catch can on if this doesn't do the trick.
Old Mar 19, 2006 | 06:21 PM
  #40
EnthuZ's Avatar
EnthuZ
So, next weekend while I'm at work, you'll swap back in my race suspension? While you're at it, be sure to install the Nismo long wheel studs & the new a-arms!
Working MOST weekends sucks!
