Best way to trailer Z
Old Feb 18, 2006 | 06:20 PM
PDX_Racer's Avatar
PDX_Racer
Default Best way to trailer Z
Should I just strap down the tires/wheels with loops around them, or are there good tie-down points under the car?
Old Feb 19, 2006 | 09:03 AM
Jason H's Avatar
Jason H
You can use axle staps, which is a 2" wide by 33" long strap with a triangle on each end, and then just feed the axle strap through your wheel and clip into the snap hooks on your ratchet tie-downs. PM me if you need anything.
Happy Towing,
J
Old Feb 19, 2006 | 07:47 PM
Redfoot's Avatar
Redfoot
There are two oval shaped holes just in front of the rear wheels along the outside rail, there are also two larger round holes just behind and inboard of the front wheels in the inner rail. To connect the straps to these holes the trailer guy sold me some T type hooks that he said tow truck operators used. You insert the Ts into the holes and then connect your straps to the eye portion of the T. I also cross my straps left to right and right to left to prevent the car from moving sideways. This is a great setup, quick to connect & disconnect, no messing around with any attachment to the suspension or drive line. If you need photos of the T hooks I'll try to get a shot this week sometime.
Old Feb 19, 2006 | 08:04 PM
PDX_Racer's Avatar
PDX_Racer
I'd love to see pics of the T hooks!
Old Feb 19, 2006 | 08:34 PM
amolaver's Avatar
amolaver
ditto - i currently use ratchet straps through the wheels. i know its not ideal, but it has worked well for me, and makes the tie down process quick and simple. a better way would certainly be nice.
ahm
Old Feb 19, 2006 | 08:38 PM
Redfoot's Avatar
Redfoot
Okay I'll get some photos posted soon.
Old Feb 19, 2006 | 09:25 PM
FibreGuy's Avatar
FibreGuy
Default This worked great
Best tie down point up front is the tow hook. Use that if possible. When these cars are shipped by train, they use these to tie them down. I bought 2 sets of cheap wheel chaulks (plastic). Placed them front of front tires and rear of rear tires. Took pieces of 2 X 4 and screwed them on the outside of all tires (to stop sideways movement) and other pieces to hold wheel chaulks in place (to stop front and back movement). Sorry that no pics were taken but the car spent 5 hours travelling on some of the worst roads in Northern Alberta. At end of trip, the car had moved approx 1/2".
All out of breath now, going to bed, feellllliiiiiiiinnnnnnnnnnngggggggg d i z z
Old Feb 20, 2006 | 07:54 AM
PDX_Racer's Avatar
PDX_Racer
Paint a number on the top of that trailer!
It makes it easy for the police to spot if it is ever stolen.
Old Feb 20, 2006 | 06:23 PM
Redfoot's Avatar
Redfoot
Default tow hooks
I use four of these
Old Feb 20, 2006 | 06:29 PM
Redfoot's Avatar
Redfoot
FibreGuy
You really don't rely on one point tie down, Do you? The Z moved 1/2" on a 5 hour trip should tell you that that is just asking for trouble. There is not much room between the wheel wells and the sides of your car in that trailer.
Old Feb 20, 2006 | 09:24 PM
PDX_Racer's Avatar
PDX_Racer
It looks like awdirect.com has them.
Old Feb 23, 2006 | 05:31 PM
PDX_Racer's Avatar
PDX_Racer
Got them today from awdirect.com, and other than the color, they look identical to the pics posted here.
At $6.99 each, they aren't that expensive.
Old Feb 23, 2006 | 07:33 PM
FibreGuy's Avatar
FibreGuy
The 1/2" of movement was actually forward in nature. The side movement was held to zero by the 2X4's screwed nxet to each wheel.
Old Feb 27, 2006 | 06:04 PM
Driver06's Avatar
Driver06
Check out a company called M&R products. They pretty much cover everything, option wise, that you could need. We have customers that use everthing from heavy duty D-rings on lca's to wheel nets.
etkms
Jun 19, 2022 06:30 PM
Vlad
Sep 27, 2003 09:27 AM
zoasis
May 27, 2003 10:17 AM
gcinfl
Dec 27, 2002 04:38 AM
