Preparing brakes for track, now low pedal - HELP!
I've also heard others say that you can actually introduce air into the system while pumping the brake pedal with the bleeder open. Unless you are just doing one full "press" of the brake pedal then close the bleeder each and every time ... that takes twice as long with a BBK where you have a total of 8 bleeders...
Have you tried to bleed the brake cylinder? You could have air trapped there if for any reason you let the fluid get too low while bleeding. Same thing happened to me and I fould a few air bubbles there.
Originally Posted by BA Cutler
This is the unit I have, it works great:
http://www.griotsgarage.com/catalog.jsp?&SKU=85700
They're are local, so very easy for me to use.
BC
BC
Thanks for the link! I've been using the mighty vac and it's crappy little reservoir;
http://www.zcarparts.com/store/merch...tegory_Code=TE
It functions fine but a complete fluid flush through all eight bleed screws seems to take 2 hours of trigger squeezing and bottle dumping, it's tedious. That Griots setup looks like it would cut the time in half - I'm there!
A quick reality check about the Griot's bleeder: since it's pulling from outside the caliper with quite a bit of force, it will pull air through the connection that it has with the bleed screw. This air won't go into the caliper, but you will see it coming through the hose into the catch-bottle along with the fluid. As a result, you can't visually tell when you've gotten all of the air bubbles out of the brake line.
This doesn't prevent me from using the Griot's bleeder, as it's great for a full flush or a quick bleed at the track if nobody's around to help, but I always have the wife come do a few pushes at the brake pedal at each caliper to make sure that no bubbles are in the system. And the Griot's piece is good for that, too...just don't pressurize it, and now you've got the world's biggest catch-bottle.
I assume you are talking about the master cylinder? How do you bleed that without actually flushing fluid all the way through?
Well, I guess I assumed it had a bleed valve. The 8 does and I thought the Z did too. If it doesn't, I don't know. I've got 5 valves on the RX-8, one for each caliper and one for the master cylinder.
The master cylinder between the base and the track model have different part numbers although they look mostly the same. My car brakes insanely good and I have the base master. Even people that have STi that have driven it they comment how good the brakes are.
This approach has yielded the best results of any tool/method I have used to date (my wife thinks this tool was well worth its cost).
I had the same experience using the Might Vac... it's great for building up your handshake grip... but it gets pretty old. The Griot's unit takes 4-6 easy pumps to create a good amount of vacuum.
I'm trying to imagine why I would go any other way. Even when I've sucked the master cylinder dry... it's not that big of a deal to rid the system of the resulting air... it's just wasteful in terms of fluid... but the tool clears the system with ease.
BC
