18's or 19's for track?
Old Jun 14, 2006 | 02:12 PM
  #81
MoodDude's Avatar
MoodDude
I measured the outside wheel lip - they are about 19.5" Of coarse the tire mounts below this point. Is that what you wanted?
Old Jun 14, 2006 | 03:30 PM
  #82
Kolia's Avatar
Kolia
I think he means the outer tire diameter.
Front 225/45R18 are ~660mm
Rear 245/45R18 are ~680mm
Old Jun 14, 2006 | 05:33 PM
  #83
MoodDude's Avatar
MoodDude
Originally Posted by TrackHoRX8
If you do that, your traction control and ABS will fault out. You'll confuse them.
All the the Z VDC cares about is the speed of each wheel and that there is still understeer in the car, so as long as the overall tire diameter is not changed, the Z is happy. This goes for the ABS as well.
Old Jun 14, 2006 | 05:35 PM
  #84
MoodDude's Avatar
MoodDude
Yea - I asked him that - he specifically asked for the 18" wheel diameter.
Old Jun 14, 2006 | 05:57 PM
  #85
shanecrosby's Avatar
shanecrosby
Just read back, and yes, I did ask the rim diameter. My mistake. I'm looking for the overall tire diameter from a Track model 18" rim with stock tires.
Thanks guys!
  #86
scubasteve's Avatar
scubasteve
mooddude.....to expand that comment, I believe that it's not just the diameter, but the difference in diameter between the front and rear wheels should not exceed a critical value which I can't remember right now. I go from 17 to 18 to 19's with no issues because it's the relationship between the front and rear wheels that matters.
-Steve
Old Jun 14, 2006 | 06:34 PM
  #87
MoodDude's Avatar
MoodDude
-Steve
Yes - you got it right. The VDC is measuring the difference of speed between the front and rear tires (and left and right, but lets hope no one is putting a different size tire on those - unless you are racing NASCAR and I would hate to see a Z do that ). So if you go smaller tires - you just got to ensure that you maintain the right ratio.
Old Jun 15, 2006 | 06:40 AM
  #88
shanecrosby
Cool. The diameter of my tire wrapped around the 19's are the same. Seems to be exactly the same but it's kinda hard to get an exact measurement w/ the car sitting on the tire. Sucks I never got to drive my car with stock track rims and tires. Searched and found the track model rims are 18lbs each. Tires maybe 25-26lbs each? Anyone wanna take a shot at this?? I'm sure I've got several extra lbs on each rim/tire...
Thanks guys.
Old Jun 15, 2006 | 07:45 AM
  #89
MoodDude's Avatar
MoodDude
Tirerack publishes the weight of all the tires they sell. Take a look and pick your tire and size and then you can figure out your exact weight.
apex locator
Jul 23, 2021 02:27 AM
