Harness bars??
Old Jan 3, 2007 | 03:10 AM
Stack's Avatar
Stack
Originally Posted by JasonZ-YA
heres a pic! the door panels are cut to swallow the forward roll bar!
Now THAT is nifty!
All you need now is some HD padding
Old Jan 12, 2007 | 02:51 PM
azula's Avatar
azula
Originally Posted by pesci
I have the BCR and love it..
http://www.bcrltd.net/index.html
did brc run out of business because that website doesn't work anymore....are there any other harness bars besides sparco??
Old Jan 12, 2007 | 07:45 PM
918 Z's Avatar
918 Z
how much was it to have that done jason?
Old Jan 17, 2007 | 05:07 AM
StaticCling's Avatar
StaticCling
I just talked with the owner yesterday, they are still in business. They are moving the website to another hosting facitilty and the transition has not been too great. I have one of their harness bars and their fire extinguisher's. Sadly, I even got to use the fire extinguisher last year.
Anyway PM me if you have any questions.
Old Jan 27, 2007 | 08:30 PM
gixracer's Avatar
gixracer
bcr is very clean and stable +1
Old Mar 17, 2007 | 05:58 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
Bump, does anyone know how i can contact BCR? I know hes a member on this site, EnthuZ, but havent seen him in a very long time..
Old Mar 17, 2007 | 10:54 AM
Redfoot's Avatar
Redfoot
you could PM him at the chicagoz site, or I could relay your communication to him. Send me a pm if that is what you want to do.
Old Mar 17, 2007 | 03:10 PM
Vq.turbo.DremZ
I just wanted to know the price and availablity... I'm looking at a number of options, and this is one of my choices
Old Mar 19, 2007 | 12:53 PM
Marc Mc's Avatar
Marc Mc
Originally Posted by 12AutoX
Here's the Sparco
It's kinda wierd in that it only mounts to the upper safety belt mounting points. It doesn't seem too stable but I haven't had any issues since I got it torqued down good..
I was looking at that photo and it sure looks like you mounted the brackets incorrectly. It looks like you have the "L" pointed away from the window, when they should cup that portion. It might just be the photo. If, however, that is the case, it might be the reason why you don't feel it is too stable.
Just a thought.
Marc
Old Mar 19, 2007 | 02:08 PM
12AutoX's Avatar
12AutoX
I see what you are talking about. It looked like there was only one way to mount them, but I will take a look and see if it is possible to swap them left for right.
Old Mar 19, 2007 | 03:46 PM
Stack's Avatar
Stack
Just a thought.
Marc
what do you mean by 'cup' that portion? If you mean the bar should follow the roofline, then the belts would be positioned too high making the angle relative to the body too steep to be very effective.
With that Sparco bar, the reason its not stable is that it does not have any other supports for rigidity. If the BCR bar had the sparco thickness, it would seem to at that point have most everything going for it (outside of roll-over protection).
The sparco model, IMO, is flawed because the leverage from 15-25 G's of load in the event of an impact might be enough to swing it around the only two points of attachment. Again, making it useless in terms of a harness mounting point. IIRC, they don't make this bar anymore... maybe thats why, I don't know.
Old Mar 19, 2007 | 04:29 PM
SinCity350Z's Avatar
SinCity350Z
Track Whore
If you knew you were going to be in a huge wreck tomorrow, would you buy a harness bar or a roll bar?
Old Mar 20, 2007 | 11:35 AM
Marc Mc's Avatar
Marc Mc
Sorry....couldn't think of the right description. Look at the bracket that mounts to the seatbelt hardware. It should be flipped so that it cups the pillar. His setup has it so they bracket doesn't do this. I think that is causing the stability issue.
Marc Mc
Old Mar 20, 2007 | 12:03 PM
Fluid1's Avatar
Fluid1
Either neither or both.
Old Mar 20, 2007 | 12:12 PM
SinCity350Z
Track Whore
By roll bar, I mean one that comes with a harness bar.
Old Mar 20, 2007 | 12:25 PM
12AutoX's Avatar
12AutoX
Just a thought.
Marc
I think you are correct about the brackets being mounted on the wrong sides. I should be able to fix it this weekend. Good eye. That should also make it impossible for the bar to flip around as Stacy suggests, though the mounting angle of the bolts makes the scenario highly unlikely.
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
