Prelim testing completed for race splitter/airdam system
Old Dec 4, 2006 | 08:11 PM
stan's Avatar
stan
sorry to hijack the thread, but i'm curious:
what is it about this design that offers so much downforce? to my untrained eye, it looks similar to what is on my ings n-spec bumper, if not a bit smaller even... is there something unique here or will my bumper have a similar effect?
Old Dec 4, 2006 | 08:22 PM
kognition's Avatar
kognition
Most splitters that have a 3" leading edge will exhibit these downforces when you are over 100mph. My information comes from a windtunnel tested SAE splitter with a 3" leading edge. It doesn't take much edge. It is really dependent on your speed. Thats all. The important issue is that your splitter can handle these loads without bending or coming apart. This splitter is also a front diffuser
under the front bumper. Much of the challenge in making these parts is in the material and the process of combining the laminates to the honeycomb core (in our case).
Old Dec 5, 2006 | 06:37 PM
knight_white99's Avatar
knight_white99
Originally Posted by kognition
This isn't a mass market part, but a full racing part. These are made the way aircraft parts are made. I'm afraid you wont be seeing discounted prices on these parts. And we are allready backordered as it is. But you are getting a great value for what it is and does. At over 100mph, you will see about 450lbs of downforce. So we will be stepping up production a bit early. And we need to restock our drivers after this weekends racing. The below pic shows damage after the entire splitter and air dam was ripped off and completely driven over this weekend. He (Steve Mott) ran it for the remainder of the weekend. It was pretty hardcore to see it ripped off and driven over! RobiSpec was so impressed, that we will be producing parts for them for their Evo customers next month.
I was pretty unhappy (as was Mike) that I ran off the track in practice (while trying to be a "nice guy" and let someone else pass) and buried the splitter into the ground. It tore off the entire lower middle section of my front bumper cover. I actually ran over the splitter - it had tire marks on it - but it stayed in one piece! I was impressed - so were a lot of other folks. Though the air dam was broken in several places, we patched it back together, drilled some new mounting holes on the front of the bumper and we got it back on the car - and it still was usable! This is tough stuff!
Old Feb 4, 2007 | 04:50 PM
kognition's Avatar
kognition
An update on this aero part for the Z. We finally sourced a rubber edge trim that
will effectively protect the edge better from gravel. And that is Kevlar under the splitter.
Old Feb 5, 2007 | 06:24 AM
John's Avatar
John
I'm interested - would like to see it in person first though...
Old Feb 5, 2007 | 07:31 AM
kognition's Avatar
kognition
Not sure if you are in S.D. now John, but i have two Z's running them at next weekends Redline Time Attack at Cal Spdwy. http://www.redlinetimeattack.com
Old Feb 5, 2007 | 07:54 AM
John's Avatar
John
Nope, not for another 3 weeks...
Old Feb 5, 2007 | 08:22 AM
kognition's Avatar
kognition
Well, we are in El Cajon, East S.D. County.
Old Feb 5, 2007 | 08:53 AM
SinCity350Z's Avatar
SinCity350Z
Track Whore
The splitter looks great on my car Mike and I can't wait to try her out at the time attack this weekend!!! I can't wait to see what it looks like with the black Nismos and hatch back on it. Don't forget to bring that poster too .
Old Feb 5, 2007 | 06:13 PM
Kolia's Avatar
Kolia
Meaning the 450lb of down force claimed is a basically a wild guess?
Old Feb 5, 2007 | 08:39 PM
kognition's Avatar
kognition
Sorry, but we don't "wild guess" or we wouldn't be in this business. You can take
a popscicle stick and get 450lb's of downforce if you go fast enough, of course it will fail due to lack of strength. Our point being, the air splitters we manufacture are capable of handling in excess of 450lb's of down force. We know this because we fail test the entire surface of the part that is exposed to air load. Your point being?
Old Feb 6, 2007 | 03:00 AM
FritzMan's Avatar
FritzMan
kognition, is that a picture of the new prototype 'lightweight' hatch in post #24?
Interested in hearing about a CF version (with OEM rear window for the street if possible).
Old Feb 6, 2007 | 03:08 AM
Jay'Z's Avatar
Jay'Z
Is this for sale yet?
Old Feb 6, 2007 | 06:21 AM
Kolia's Avatar
Kolia
I didn’t mean to offend you or anybody.
From what I can see on the picture, your splitter is certainly functional and well built. Tests on the race track certainly back up it's effectiveness. I’m just curious to know how you went about finding these numbers. Did you measured the ride height at speed, or installed load cells on the mounting points?
A reference to some similar splitter used on a different setup is hardly a reliable source. The defensive stance you’re suddenly adopting suggest no measurement were made. If you had, I would have had my answer straight up…
Now you’re saying it can withstand 450lb of load before failure. Unless it has failed during test, that doesn’t mean it will generate that amount of down force.
I might not an aerodynamicist; I’m not even an engineer. But I have worked as a designer to some trick wind tunnel facilities and I’ve seen a couple of aero packages.
Old Feb 6, 2007 | 07:47 AM
kognition's Avatar
kognition
No that is the new invisible hatch.
Yes the kit is now in production and available.
Old Feb 6, 2007 | 08:01 AM
kognition's Avatar
kognition
No offense taken, i had a stressful day yeserday and i did not intent to sound
like i was offended.
You are right, we do not use load cells for testing.
The SAE splitter that was tested is in my possession, not just numbers picked from the web. And the customer who paid for the testing is also my customer
RobiSpec (Robert Fuller). We produce splitters for their Evo's. Very close in surface area to our Z splitters.
We mount the test part securely, and we apply an even downforce on the exposed edge until the part fails. And as an fyi, it extends behind the front bumper 16 inches back. It is also funtioning as a diffuser. I wish i had a wind tunnel.
Old Feb 6, 2007 | 08:25 AM
Kolia's Avatar
Kolia
Thanks for the clarifications. And I’m sorry if my comments came across in a negative way.
That piece looks great. Is it mounted to the bumper beam of just the skin?
A set of laser range finders would be a good investment for fine tuning various designs. That’s what we used. Correlating ride height with aero loading. Having two give you the chance to verify your front to rear balance too. I don’t know how much of an investment that would be…
Old Feb 6, 2007 | 09:02 AM
  #38
kognition's Avatar
kognition
Thank's Kolia
Well i hope that as we progress into making the more sensitive parts that affect the cars handling, we can invest into equipment like that.
Yes this one pictured is mounted to the bumper skin. The rear of the splitter is bolted to the skid plate underneath. We will develop a bracket mounting setup to attach to stock points under the chassis in the next month. The next goal for us is an undertray kit, and to develop that into a fuctional part.
  #39
Mike Wazowski's Avatar
Mike Wazowski
looks good
Old Feb 6, 2007 | 09:08 AM
  #40
julian's Avatar
julian
i can already picture what would happen if people put the front splitter on without adding downforce in the rear....
