Does the Nismo wing add any downforce?
Old Dec 20, 2006 | 11:44 AM
Kolia's Avatar
Kolia
Originally Posted by daveh
You're right that it will be out gunned in TTB, but... It will make a nice TTC car
Lol...
Goog point!
Old Dec 21, 2006 | 09:49 AM
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
The NASA TT rules have been released for next season and I am being heavily penalized for my nismo wing because it is longer than 8" from front to rear of the car (it is 8.5" to be exact).
It may be possible to take it to a fiberglass shop and have them cut off a 1/2
" and reconture it accordingly.
The cost of modification may be worth the NASA points.
Old Dec 21, 2006 | 10:59 AM
daveh's Avatar
daveh
I've actually made the decision to slow the car down rather than work to make it faster for next season. I will be removing some parts and running down a class in TTC. To be competative in TTB next year, I'd have to spend too much on parts that make more sense in terms of lap times. (ie ditch the nismo wing and get a real one). I really was doing the old 'run what you brung last year' because I put the car together before I was competing. I don't think I would do well if I field my exact same car next year.
However, with all that I am removing, I think I can have a car within 1-2 sec of what I had last year.
Old Dec 21, 2006 | 12:43 PM
Kolia's Avatar
Kolia
I'm very interrested in the removed parts now...
Old Dec 21, 2006 | 02:08 PM
Hydrazine's Avatar
Hydrazine
If the rules allow it, you need a plenum spacer on that thing.
Old Dec 21, 2006 | 02:16 PM
Abishop's Avatar
Abishop
downforce, slim to none
Old Dec 21, 2006 | 02:18 PM
_Donovan_'s Avatar
_Donovan_
is the little lip that is on most Z's aloud?
Old Dec 21, 2006 | 02:46 PM
daveh's Avatar
daveh
Ha, the REAL go fast parts are staying on the car
Wing's and noisemakers are gone.
Only thing I've got that might be of interest is some R-comps.
Old Nov 27, 2012 | 05:35 AM
nismozallday's Avatar
nismozallday
The nismo rear spoiler goes together with the aero package on the nismo 350z together it creats 11 lbs ofdownforce in front and 33 lbs of downforce rear when removed see if you feel the difference since a a stock z actually creates 70 something lbs of LIFT in the rear and several more lbs of lift in front.........if its short course needing excellent handling you may want to keep
Old Nov 27, 2012 | 06:15 AM
KingBaby's Avatar
KingBaby
Hardest Setting
You like bringing back old threads, don't you?
Old Nov 27, 2012 | 01:25 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
You might be right, but the thread is about the original Nismo S-Tune wing, not the Nismo wing that came from the factory with Nismo 350Zs.
Old Dec 3, 2012 | 12:07 PM
scotts300's Avatar
scotts300
You mean the NISMO V3 package? Do you have a source? Also, those numbers are usually referenced with an associated velocity. . .
Old Dec 3, 2012 | 01:29 PM
Chebosto's Avatar
Chebosto
if you got someone to translate japanese, i have those older Z magazines where it discusses the older Stune Z design... and i think the newer V3 design comparison.. has small fancy CFD picture of air pressures..
apex locator
Jul 23, 2021 02:27 AM
nanotech
Oct 2, 2015 05:02 AM
