Who makes small track/tire trailers?
Old Mar 15, 2007 | 06:18 AM
Kolia's Avatar
Kolia
Default Who makes small track/tire trailers?
I’m in the market for a small tire hauler to pull to the race track with the Z.
I’m having a hard time finding manufacturers! What ever search I do, I’m flooded with big car trailers…
Any brand names or links?
Old Mar 15, 2007 | 06:51 AM
John's Avatar
John
I believe Jason Henderson has an option or two. By all means, stay away from the HarborFreight ones...
Old Mar 15, 2007 | 07:00 AM
MoodDude's Avatar
MoodDude
I have a harborfrieght one and it works great, as long as you follow the directions and install the 3/4" plywood that is not supplied with the trailer. If you don't that is when people have problems with them.
Old Mar 15, 2007 | 07:01 AM
PDX_Racer's Avatar
PDX_Racer
I'm going on year four with my HF trailer. All I've done is made sure that the wheel bearings are re-packed each year with synth lube.
Of course, I made sure that the frame bolts are all tightened. If you're really concerned about them loosening up over time, star washers will alleviate most of that concern.
Old Mar 15, 2007 | 09:59 AM
betamotorsports's Avatar
betamotorsports
Or a few beads applied by your local handy, dandy welder.
Old Mar 15, 2007 | 10:36 AM
John's Avatar
John
You all have had better luck than I did - my tongue bolts sheered straight out of the frame and nearly caused a huge accident on my 3rd use. I should have taken it back when I was first assembling it though as there were certain parts that really didn't sit flush with each other, but somehow those didn't fail.
Old Mar 15, 2007 | 11:48 AM
DmanG281's Avatar
DmanG281
I bought one from Lowe's and couldn't be happier. I attached a security box for a truck bed to the front of it and welded up a tire carrier that puts the weight of the tires over the axle. Put my jack in a rubbermaid container behind the tires and its perfect 60/40. It's about $200 more than a HF trailer but with that comes less hassle. The only real thing I had a problem with was the ramp in the back of it being to high. I took a plazma cutter to it and welded on another piece of L stock and its fine. Good build quality also. Comes enamel coated and pre wired.
This is the trailer
http://www.lowes.com/lowes/lkn?actio...6XG&lpage=none
This is almost like the box I have but mine has cup holders on the top plus a sliding drawer in the lid for my numbers.
http://www.lowes.com/lowes/lkn?actio...725&lpage=none
Old Mar 16, 2007 | 12:08 PM
mberthia's Avatar
mberthia
How did a Titan morph itself into a Civic ??
Old Mar 16, 2007 | 12:14 PM
Kolia's Avatar
Kolia
It rained and melted... A Civic was left in it's place...
I'd like to buy a house sometime before retirement, so I got rid of the big truck I seldom used as a truck. Plus, the monthly fuel bill of the Titan was about the paiment for the Civic...
I sure miss it though...
Old Mar 17, 2007 | 11:53 AM
DriveI65's Avatar
DriveI65
I swung by Lowes before my car club meeting and looked it over. Nice but it looks like it weighs way more than my HF POS. 4x6 is pretty big. How far have you towed it with your Z? Which hitch are you using?
Old Mar 17, 2007 | 11:58 AM
Kolia's Avatar
Kolia
I'll check out the trailex tire totte.
I need something that can go 75 mph for 800+ miles...
Thanks guys!
Old Mar 17, 2007 | 06:33 PM
DmanG281's Avatar
DmanG281
I use the hitch that one of the guys on here sold. Roark I think or something like that. I've trailered it 400 miles on the Highway at 80 with no problems. It was much better on gas after I trimmed the gate off. I check my hitch regularly and have no cracks or problems even after being rear ended with the hitch ball connected. The trailer is pretty big but it is very smooth on the highway and the leaf springs do help a bit. It's not the biggest trailer I've seen being pulled by a Z.
Old Mar 17, 2007 | 06:37 PM
John's Avatar
John
Yeah, Jim's (roark) hitch was well-designed. We actually just uninstalled mine several weeks ago and found some serious cracks on my bumper supports, so if you have a 2003, be sure you get the bumper mount joints reinforced with an extra weld as Jim recommends...
Old Mar 17, 2007 | 06:42 PM
DmanG281's Avatar
DmanG281
Yeah I have an 05 and my supports are a bit beefier than the ones you guys have. Even that being the case I had all the seems welded in addition to the factory welds.
Old Mar 17, 2007 | 06:54 PM
DriveI65's Avatar
DriveI65
I have a unit patterned on Roark's design. I had my 03 supports welded last years ago to stiffen them. We had a guy in Atlanta rear end us and the hitch sheared off not harming the bumper steel or frame but the bumper cover and a quater panel took a hit when the trailer was pushed into the car.
The hitch was moved to my 2007 a couple of weeks ago and we still stiffened the supports to be safe. I've towed from N. Al to Ft. Myers, Norfolk, Peru and Topeka besides the local events within 200 miles. Gas milage goes down a couple mpg towing.
Old Mar 18, 2007 | 07:25 AM
myG35zx's Avatar
myG35zx
I purchased a 4x6 from Home Depot and then had my shop remove the steel bed, install aluminum diamond plate in its place. Then they fab'd up a tire carrier then mounted a box from Lowes to hold tools, parts and other things. I wanted 6 feet length so that my ez-up tent and nitrogen bottle fit with ease. With 75 pound tongue weight it works like a champ.
See link: https://my350z.com/forum/showthread....hlight=trailer
Old Mar 18, 2007 | 08:46 AM
C Ray Z's Avatar
C Ray Z
Default Four Years towing This Trailer
I built this from Northern Tool High speed trailer. The Aluminum box also from Northern and the wheel cariaer is my design and made locally. Total cost 700.
Attached Thumbnails Who makes small track/tire trailers?-trailer-photo.jpg
Old Mar 18, 2007 | 08:10 PM
PDX_Racer's Avatar
PDX_Racer
I pulled my 8" wheel HF trailer to Topeka and back (4000 miles) at 65+ MPH. I just made sure that the wheel bearings were freshly packed with hi-temp synthetic bearing grease before the trip.
Old Mar 19, 2007 | 05:50 AM
drivesolo's Avatar
drivesolo
BA_Cutler was late for an event a few seasons back and he was blasting down the Highway w/ his HF trailer in tow in excess of 90 MPH. Not recommended, but that little 55 mph speed limit sticker on the wheel seems to be very conservative. I've had mine up to 75 mph for brief periods.
Old Mar 19, 2007 | 08:37 AM
mhoward1's Avatar
mhoward1
Another to look at is the Northern Tool One. It's about the same as the HF one, BUT...
The Frame has an additional cross brace, it comes WITH a title, it rated for Highway speeds. it comes with 8,10,12, and 14 tires if you want. They also sell a bunch of accessories at the store.
