Stock stud length?
Old Mar 24, 2007 | 08:03 PM
Kirkster's Avatar
Kirkster
Default Stock stud length?
Anyone know the length of the stock studs. I had one of my Eibach studs seize and need to get a new one, but am not sure which length to get. I am running a 1/4 inch spacer in the front for AutoX.
K
Old Mar 25, 2007 | 09:23 PM
03Z33's Avatar
03Z33
The stock front studs are right around 42-46mm (sorry don't remember exact length). If you don't plan to go thicker than 1/4" (7mm) spacer you can get away with 50mm studs or you can use 60mm studs which will give you some extra threads (but you may need to run open ended lug nuts). Nismo make both lengths, you can also purchase Moroso or ARP studs by searching out the part numbers on this forum.
Old Mar 25, 2007 | 11:32 PM
terrasmak's Avatar
Ichiba has the longer studs listed on there site, and there only $2 and available in whatever size you need.
Old Mar 27, 2007 | 05:29 PM
Kirkster's Avatar
Kirkster
Thanks for the info...
I picked up ARP studs from www.splparts.com
sales@czp
Sep 23, 2019 03:30 PM
