Rebuilding and repainting Brembo calipers
Old Apr 5, 2007 | 11:27 AM
Resolute's Avatar
Resolute
Excellent post. Thanks for taking the time to make things so clear and provide so many pictures. Top Notch! I second the sticky idea.
Will
Old Apr 5, 2007 | 10:43 PM
Kolia's Avatar
Kolia
Originally Posted by dnguyent
Commasense, just curious as to how you like the XR2/Spec VR set up. Are you having any abs/ebd issues with so much rear bias? I ran the Spec VR's up front, and they have some bite to them! I have installed XR2/GT Sports, but haven't put them to test yet.
Brake bias will be WAY forward with a XR2/SpecVR setup.
The XR series is the new carbon/ceramic compound. The XR2 is for GT race applications (Speed challenge, Koni Challenge,...). The XR1 is for NASCAR and the XRT is for "heavy downforce application". The XR2's torque figures where described to me as "Much higher than the SpecVR's, with the same curve profile".
I'll be running a XR2/XR3 combo on my next track day. I have the pads already and they are hot !
Old Apr 6, 2007 | 07:01 AM
commasense's Avatar
commasense
Thanks, Kolia for clarifying that. I forgot to explain the characteristics of the new XR2s. The folks I spoke with at Cobalt thought the XR/VR combo would work okay. Do you think it might be too front heavy?
Old Apr 6, 2007 | 01:35 PM
Kolia's Avatar
Kolia
Too front heavy ? I don't think so. The EBD will just send as much pressure to the rear as it can. The car will brake fine, with the rear end more "civilized" at turn in with less rear brake bias.
You'r brake distance will probably be a bit longer than with a XR2/XR3 combo, but still shorter than with an all SpecVR setup. (All speculations of really...)
We're not racing, so let's just have fun driving. All I ask from my brakes and tires is to last a whole session with no fade. The rest is just extra stuff.
Old Apr 8, 2007 | 05:40 PM
dnguyent's Avatar
dnguyent
Are you sure you're not confusing the Spec VR with the GT Sport? The SpecVR's are rated with a mu=0.64, and it was Cobalts 'aggressive' stuff last year. Although I don't have the torque curve data, the SpecVR friction coeff seems kind of high to be eclipsed by the new XR2 compound. Isn't 0.64 pretty damn high?
On another note, the 355 mm Stoptech kit does move bias towards the rear as compared to the OE Brembo and 332mm Stoptech kit. So, I have to run a low friction compound in the rear, or end up with premature rear ABS actuation.
I agree that the new Cobalt line of brakes do look hot!
Old Apr 9, 2007 | 03:33 AM
Kolia's Avatar
Kolia
No mistake there. XR2 = more torque than SpecVR.
Got that from Glenn at Cobalt Friction. Call him if you want ! His exact words when I asked if they had similar torque to the Spec VR were "No no no. The XR2 have much more torque, with the same profile as the Spec VR."
Old Apr 10, 2007 | 09:30 AM
dnguyent's Avatar
dnguyent
That's really good news for me then...Hopefully, I'll get brake bias moved more forward. On another note, I heard the new Sport GT's also have more friction than the old formula. Apparently, some folks are having bias issues with the new Sport GT's when they expected similar characteristics to the old version.
Seems that Cobalt is taking forever getting their torque curves published online.
Old Apr 11, 2007 | 12:04 PM
Kolia's Avatar
Kolia
I should have some decceleration curves when I go to MidOhio. It'll give us an idea.
My first time on an all SpecVR setup was very interresting. Braking wasn't simply about hitting the brake pedal. I had to balance the car too! Much more fun!
Old Apr 17, 2007 | 01:21 PM
Kolia's Avatar
Kolia
James, do you remember the part number for the replacement seals ?
I ordered a "standard" seal rebuild package online, plus I now have the anti-knock back seals from the HRP web site. And no two seals are the same size ?!?
By any chance, did you measure the seal diameter ?
Old Apr 18, 2007 | 05:14 AM
commasense's Avatar
commasense
I don't still have the part numbers handy, although you could check with Dave Zeckhausen. According to his Web site, the part numbers are:
143.99040 (rears, one kit)
143.99038 (fronts, one kit)
143.99044 (fronts, one kit)
The last two digits are the piston size in millimeters.
Old Apr 18, 2007 | 06:12 AM
THE TECH's Avatar
THE TECH
Very informative. Nice write-up!
Old Apr 18, 2007 | 06:21 AM
GodSendsDeath's Avatar
GodSendsDeath
Good stuff, even though I own a Z and its not a 350z, but a Z4 BMW its still good news. Might be able to apply this to my car. Bookmark and thanks for taking the time to write this up.
Old Apr 18, 2007 | 06:51 AM
Kolia's Avatar
Kolia
Oh...
The P/N on one of the Brembo seal kit I have is 44124-12U00
Old Apr 18, 2007 | 07:02 AM
commasense's Avatar
commasense
Sorry, I forgot to mention that my kits were Stop-Tech, so the part numbers are probably different from Brembo OEM numbers. But the 44 looks right.
Old Apr 18, 2007 | 07:31 AM
Kolia's Avatar
Kolia
Yeah. But that's where the fun starts !
That seal has an ID of 41mm and OD of 44mm. I was expecting an ID a bit smaller than 44mm
On the other hand, the anti-knock back seal I have are 38mm ID and 44mm ID respectively. With no documentation provided, just the seals in a bag...
I'll have a few phone calls to make I'm affraid...
Old Apr 18, 2007 | 09:16 AM
mistico's Avatar
mistico
Great thread.
Thanks.
Old May 3, 2007 | 12:06 PM
spacemn_spiff's Avatar
spacemn_spiff
Great Thread all and to the OP. Kolia keep us updated about how it works out for you.
Old May 3, 2007 | 12:09 PM
  #38
Kolia's Avatar
Kolia
I have to take these pictures!
I haven't changed the seals yet. Confusion in seal sizes... But it's interresting to see the inner race of each seal. The regular one are smooth, almost mirror like, while the AKB are much rougher.
Old May 4, 2007 | 10:12 AM
  #39
bbs350z's Avatar
bbs350z
brake guru? i think so. excellent write up
Old May 7, 2007 | 02:33 PM
  #40
commasense's Avatar
commasense
The final touch, weeks later than I expected: painting the Brembo logos.
Not really much to tell: I had my local sign shop make the stencils in vinyl, I applied them, masked off the area, and sprayed them with three coats of red High Heat Duplicolor paint. After the paint dried for an hour, I removed the stencil, and there you go: a custom, one-of-a-kind Track caliper paint job.
Attached Thumbnails Rebuilding and repainting Brembo calipers-img_1116a.jpg   Rebuilding and repainting Brembo calipers-img_1118a.jpg   Rebuilding and repainting Brembo calipers-img_1119a.jpg   Rebuilding and repainting Brembo calipers-img_1127a.jpg   Rebuilding and repainting Brembo calipers-img_1129a.jpg
