Track Alignment; too much for VDC?
Old Jul 9, 2007 | 04:33 PM
Sk8fe's Avatar
Sk8fe
Question Track Alignment; too much for VDC?
350Z Track Guru's:
I run my 2003 Track Ed. in Driver Ed. events mainly at Summit Point and Watkins Glen. I am recently experiening a problem where both the "VDC OFF" and the "SLIP" lights are coming on shortly after I drive my Z on the street (within 5 or so minutes) and pressing the "VDC OFF" button once these come on doesn't seem to help. What does this mean? I have not have this problem before.
This Spring I got my Z corner balanced and last week my Hotchkis 3-way adjustable swaybars set to their stiffest setting. I just got my Z aligned this afternoon to the specs below. Is my alignment causing these lights to come on or setting my sways to their stiffest setting?
Note, when I got my Z corner balanced the right rear toe would go way out of wack. I purchased and installed SPC toe bolts in the rear and now that allowed me to get more adjustability. For Driver Ed. track use, what are recommended alignment specs? From my reasearch on here, I thought that these were in the range of what people were runing/recommending?
Thank you for your time and help. I greatly appreciate it.
Old Jul 9, 2007 | 05:11 PM
tmak26b's Avatar
tmak26b
I wouldnt worry too much about it, it looks fine for what you are doing. You shouldn't be using VDC if you are worried about performance anyway, they will kick in and control the car.
Old Jul 9, 2007 | 05:35 PM
DavesZ#3's Avatar
DavesZ#3
VDC shouldn't be affected by an alignment unless the alignment was so extreme that unusual tire slippage was possible. TCS/VDC are most commonly thrown off by non-standard stagger (front tire diam vs. rear diam).
Old Jul 9, 2007 | 05:36 PM
Sk8fe's Avatar
Sk8fe
I'm trying to figure out why they all of a sudden came on. I do drive my Z on the street, it is not a dedicated track car AND I do not want to be driving with those lights constanting on (annoying).
I keep my VDC on at the track so when the SLIP light comes on I know I am not smooth enough and where I need to work.
Old Jul 9, 2007 | 05:53 PM
spf4000's Avatar
spf4000
It could be a problem with your ABS sensors. Debris could have gotten on one of the sensors, causing your car to think one of the tires is slipping. *Shrug*
Old Jul 10, 2007 | 02:35 AM
Sk8fe's Avatar
Sk8fe
Where would I find the sensor once the wheels are off and how would I clean them? Spray them with BrakeClean?
Old Jul 10, 2007 | 03:29 AM
tmak26b's Avatar
tmak26b
The one with the electrical wire on it
Old Jul 10, 2007 | 09:56 AM
spf4000's Avatar
spf4000
The one that I'm talking about are the rear ABS sensor rotor. This is the one most susceptible to getting stuff on it. It's on the rear drive shafts right next to the diff.
Attached Thumbnails Track Alignment; too much for VDC?-rear_diff.jpg   Track Alignment; too much for VDC?-sensor_rotor.jpg
Old Jul 10, 2007 | 01:06 PM
Sk8fe's Avatar
Sk8fe
Thanks! As soon as it gets below 100 here (heat index anyway), I'll get my Z up on jackstands and check it out as well as each of the corners.
Old Jul 13, 2007 | 11:00 PM
STRETCH's Avatar
STRETCH
It could also happen due to the steering position sensor being out of whack after the alignment. That happened after JIC did my corner balance. Just had to stop at the nissan dealership and have them wipe the code. It was all good :-)
Old Jul 14, 2007 | 05:36 PM
Sk8fe's Avatar
Sk8fe
Default Update
I figured both lights coming on meant that it was shuting itself down completely. Since this started happening I made two changes to my Z's suspension & alignment setup.
1. Was putting the sway bars on their stiffest setting (not likely the cause)
2. Added toe in the rear (0.15).
I took my Z back to STS Tire and told them to set the rear toe as close to zero as they can and then do any fine adjustment to the front toe as needed to get the steering wheel pointing straight, etc. They reset the rear toe to 0.08 for me and that did the trick!
For my year 350Z (2003), appearently the VDC does not like any toe in the rear. Just wanted to provide an update in case anyone stumbles across this problem.
Thanks for all your help.
Old Jul 15, 2007 | 07:15 AM
tmak26b's Avatar
tmak26b
zero toe is also a great way to take stability away from your car and cause you to spin, just ask what happened to all the 91-92 MR2 owners.
Old Jul 15, 2007 | 07:42 AM
Sk8fe's Avatar
Sk8fe
Technically my rear toe is 0.08 now. According to STS' computer, rear toe spec for my year Z is 0.06 to 0.10. I had 0.15 which caused my problem. Resetting back 0.08 fixed my problem. I just posted so others could benefit.
I do not care about 91-92 MR2's. How is that relevant? Its a totally different chassis?
Old Jul 15, 2007 | 10:46 AM
John's Avatar
John
Check your brake fluid level. If it gets near the Min, then those lights will come on.
Old Jul 15, 2007 | 09:22 PM
tmak26b's Avatar
tmak26b
Is your car different because it is on rails? If so, perhaps losing the rear end is not a problem you have to deal with. I really hope your VDC works good, else zero rear toe is going to get you in a a lot of trouble.
If you don't believe me, read about how toe in and toe out works. What works in the front basically applies to the rear of the vehicle. If snap oversteer is something you like, go right ahead and put in negative or zero toe. I am simply trying to correct your zero toe comment, that's the worst thing people can do. The best advice for novices is leave the car alone and learn how to drive it properly, tinkering is not always the best. Driver should be > than the car and setup.
Old Jul 15, 2007 | 09:24 PM
tmak26b's Avatar
tmak26b
There, I am sure your rear brakes will love you when your VDC doesnt have to keep applying the brakes to save your back end
Old Jul 16, 2007 | 02:43 AM
Sk8fe's Avatar
Sk8fe
Good to know, but my brake fluid level is always at max.
Old Jul 16, 2007 | 03:03 AM
Sk8fe's Avatar
Sk8fe
tmak26b, my "zero toe" comment was not 100% correct since I am technically not at zero toe, thank you for pointing that out. Are you done slamming me now?...
Old Jul 16, 2007 | 04:03 AM
tmak26b's Avatar
tmak26b
Nothing personal, just pointing out something you said incorrectly
apex locator
Jul 23, 2021 02:27 AM
Depravity
Oct 1, 2015 04:49 PM
