for those who tracks and autox their car a lot
Old Aug 26, 2007 | 08:23 PM
tmak26b's Avatar
tmak26b
Default for those who tracks and autox their car a lot
For those who race their car a lot, you might want to check the top 4 strut mounting bolts at the top of the car. I have 43K miles on my car, about 400 autox runs and 3000 track miles in a stock car. My car started developing a clunk under braking, I checked my front end over and over, but there was nothing loose. By luck, I decided to tighten a lot of bolts in preparation for my next track event. During my inspection, I found the mounting bolts to be loose. After I tighten them, most of the clunks went away. If you drive your car hard, you might want to check it in order to eliminate clunks and perhaps a strut falling off. After all, it's a Nissan. You never know
Old Aug 26, 2007 | 10:52 PM
XuperXero's Avatar
XuperXero
Good advice, I'll tighten all the bolts and screws all around... Got some clunking and clicking lately.
Old Aug 27, 2007 | 06:08 AM
BloMyS14's Avatar
BloMyS14
Mine too, I hear a little clunk every now and then under hard braking.
Old Aug 27, 2007 | 06:55 AM
tmak26b's Avatar
tmak26b
tmy clunk was weird. it would only happen under braking and then turn the wheel left. the back is still clunking slightly. i tighten thr botom nuts. let me see wha i will find up topnight
Old Aug 27, 2007 | 08:28 AM
Fluid1's Avatar
Fluid1
Where the strut tower brace connects to the top of the front suspension?
Old Aug 27, 2007 | 11:18 AM
tmak26b's Avatar
tmak26b
nope the 4 12mm under it. you have to remove the beace
Old Aug 27, 2007 | 07:19 PM
Kolia's Avatar
Kolia
I'll check that out this week. Mine kinda creaks sometimes.
Old Sep 20, 2007 | 08:07 AM
Pufferfish's Avatar
Pufferfish
i have 2 track days in on my new 07 G coupe and i have all sorts of creeks and rattles that sound exactly like loose parts. its especially noticable in the city where the roads are real bumpy. i looked at the bolts that hold the struts on top and they don't appear to be loose (no wrench at hand to find out for sure though). are there any other areas that could be causing this? i replaced the pads and forgot to put the little spring steel tabs into the loops on the pads. could this be the reason? i have heard they are there to prevent the pad from moving around, but the car makes noise even while braking. anyone got more input? i have another event next friday and i don't know if i can get it in to be serviced in that time.
Old Sep 20, 2007 | 08:27 AM
daveh's Avatar
daveh
You should have thrown some koni's on while you were in there
Just to clarify, are you referring to the bolts that hold the front shocks in? Aren't there only 3 of those?
I belive my upper mounts from unitech use self locking nuts. The torque spec is really low for those nuts too if I recall correctly.
thanks for the post
Old Sep 20, 2007 | 03:35 PM
Kolia's Avatar
Kolia
Easy torquing these nuts guys!
26-30 ft.lb is enough. Don't snap them!
etkms
Jun 19, 2022 06:30 PM
May 12, 2016 07:42 PM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
350Z Project X
Oct 17, 2015 05:16 PM
