1st time autocross,what tire pressures?
Old Oct 12, 2007 | 04:49 PM
whitt1's Avatar
whitt1
Default 1st time autocross,what tire pressures?
I'm planning to autocross my NISMO Z this sunday in Little Rock,What tire pressures do I need to start out with?I'm running the stock Bridgestones.I was thinking 45 front and 40 rear.
Old Oct 12, 2007 | 04:58 PM
I run 40 PSI all around.
Old Oct 12, 2007 | 05:50 PM
DavesZ#3's Avatar
DavesZ#3
40f/35r.
Old Oct 12, 2007 | 06:54 PM
DriveI65's Avatar
DriveI65
For streets I prefer 38F, 36R.
Old Oct 12, 2007 | 07:36 PM
whitt1's Avatar
whitt1
Thanks for the replies,the last car I autocrossed was my Lotus Elan and a CRX before that,the Z is fresh territory.I 'll start with 38Fand 36R and put a little white shoe polish on the edge of the sidewall.
Old Oct 12, 2007 | 08:53 PM
tmak26b's Avatar
tmak26b
Hmm..35psi works great for me
Old Oct 14, 2007 | 09:36 AM
Scarab440's Avatar
Scarab440
37 Front and 35 Rear in street tire class.
Old Oct 14, 2007 | 09:54 AM
dmoffitt's Avatar
dmoffitt
on a square setup (275/40/18) I run 37 front 34-35 rear - seems to work well to balance the car. Then again the car is more setup for roadcourse use, with the rear sway set on full soft / it's not as easy to rotate (pushes a tiny bit on corner entry, it could be that I'm just going too fast on street tires hehe)
Old Oct 16, 2007 | 06:40 AM
Lucino's Avatar
Lucino
ran last weekend with 35psi all way around. it worked fine for me, and my instructor told me to.
correction: I was running 40psi hot and the wear on the outter edge of the tires were right on.
Old Oct 17, 2007 | 06:30 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Too high. The best I found at my Autox was around 39 front 38-37 rear. All depends on the surface type obviously as well.
Old Oct 22, 2007 | 12:29 PM
mw9's Avatar
mw9
Did my first autocross over the weekend, find out that I have alot too learn. One thing that I saw was people feeling their tires after every run and some people were spraying their tires with something. Does anyone one know about this. I think I was running about 40 PSI
Old Oct 22, 2007 | 02:29 PM
tmak26b's Avatar
tmak26b
They have race tires, your street tires don't need that. You might want to drop the tire pressure so you are using the whole thing, not just the center of it. Modern tires are built a lot stronger than the older ones, you don't need to pump it 5psi more than stock to prevent it from rolling over.
Old Oct 22, 2007 | 03:32 PM
DriveI65's Avatar
DriveI65
FYI
The latest craze in STU when there are two drivers is to keep 4 towels in a cooler with water and ice. When they get in grid after a run, they put the wet towels on the tires. Pretty inventive. I've used ice in the sprayer but they have taken it farther.
liqalu04
Jan 2, 2022 12:58 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
nanotech
Oct 2, 2015 05:02 AM
Dymsi
Sep 29, 2015 11:32 AM
SharX59
Sep 27, 2015 09:23 AM
