daily driver vs track dedication
see this is the delema
my stock seat cloth track creaks and bends + with helmet i am too high
6'5" and shrinking
its either a evo II or a circuit
i will be getting a roll bar soon after the seat and the bcr harness bar will be gone.
the seat will only be in for track days but the roll ar is next
but my original question how far does it go before it is done on the street?
long term, 3 years its not on the street or another full prepped car will be purchased and the z sold.
and my wife and i will get something new to cruise around in, but for now its our leave the kids home and go out for the night.
6'5" and shrinking
I only have dampers and front A-arms. I change wheels and pads for track days. Change the front alignment too.
The car is a blast on the track. But lapping is just for fun. I feel I've reached a plateau now. The car is great on the street also.
I'd get an LSD next. But after that, roll bar/cage + seats is the next step and streetability will be questionable... Even with padding, I'm not sure I'd want to get in a fender bender in a rollbar equipped car, without a helmet.
The breaking point for me is the roll cage vs. roll bar vs. harness bar issue, which dovetails into the seat issue. These things separate a track car from a streetable car for obvious safety reasons.
I got around the spring rate issue by staying relatively soft, (under 500 lb.in.) and using Koni SA's.
The clunky Nismo LSD is streetable, but definitely not civilized.
As far as installing steel tubing in the passenger compartment, I suppose the compromise is the 4 pt. roll bar type that won't cause an injury in an accident if the driver isn't wearing a helmet. Regardless, that ruins the trunk space for tires/tools.
Obviously there is a compromise between having a full track oriented setup versus something that sees both track and street. The only person who can answer the question of how far you want to compromise in either direction is you. Good luck either way!
how much and what do you have done ? what spring rate?
Originally Posted by John
Most of the sponsored ones are slow with good marketers behind the wheel (with the few that actually compete in sanctioned races). There are several 350s floating around as exclusive track cars - however, I will consur that they are far and few between, which to me is still surprising.
Mine is a dedicated track car. Trailer and everything...I've already replaced an engine and one transmission...My 5th gear is grinding, it might be time for a new one
Originally Posted by Equinox
The simple answer to your question is "it depends.." Some people are ok with having a gutted car with kidney-jarring ride on the street, others want to maintain full stereo, interior, etc.
We build more track going 350Z's than probably anyone in the country, or at least the west coast. Let me know what you might need help with.
. Question...even though I hear no noise in the front wheel bearings, what kind of schedule should I maintain in replacing them...I do all the above said maintenance, brakes, all fluids (sometimes compression tests)and even tighten every bolt under my car, but I've never replaced my front hubs. For piece of mind, once a year, every other year? I track normally once a month at most, sometimes during downtime (like for the engine) every couple of months...any help would be much appreciated!
Originally Posted by WA2GOOD
^^ Whats up (Stretch), Haven't had time to talk to you much lately, give me a call when you get a chance.
Check the upcoming Winter '08 issue of Nissan Sport Magazine for more specific info (including part #'s) on this very issue. How often to change those bearings depends on your experience at the track- going off track, hitting curbs, etc. may shorten the wear cycle considerably.
David Muramoto
Editor-in-Chief
Back on topic- having driven several track-ready cars (rollcage, race seat, etc.) as a DD, it gets old quick. The very things that keep you safe on the track make it hard to enter and exit the vehicle. I still use my FWD ITA 200SX Se-R as a winter car in Colorado, and it constantly serves to remind me what a PITA it is!
Originally Posted by dkmura
It sounds as though you've got a lot of track miles already on your Z. You're asking the right question in regard to replacing the hubs. But for real peace of mind, I'd suggest replacing both the front and rear hubs as a set. Pack your old bearings carefully into a box and bring them with you as an emergency backup at the track.
David Muramoto
Editor-in-Chief
David Muramoto
Editor-in-Chief
Thanks for the response David. Also, to add to your point, from experience, driving on the street with a rollcage and not having a helmet scared the hell out of me. One accident and I could crack my head open!
David Muramoto
Editor-in-Chief
David Muramoto
Editor-in-Chief
Originally Posted by Dave 90TT
Yes, if you are going towards an all out race car. I am not, as I stated. I want to maintain my daily driving comfort (or as comfortable as the sport suspension is) and still stiffen it up for the track.
if you want to maintain a somewhat civil ride on the weekdays, it has been recommended to me that cusco zero-2's, or kw variant 2's are just the key. not as stiff as the jic's or the tein flex's, but can be adjusted with a decent amount of adjustability for track days.
So, what then are some other suggestions that are easily adjustable between stiff track weekends, and soft for daily driving (30+ miles one way) on regular roads?
If they are still available, get the TC Kline double adjustable Koni's. There is a group buy in the competition section of the marketplace. Then get a set of the nissan motorsports T2 springs. The car is very flat and responsive. The springs are very stiff, but the dampers are valved to work with these rates, hence they have a very good ride.
I recently changed over from my JDM coilovers to TC Klines and T2 springs and couldn't be happier. The Koni's have a wide range of adjustment that allows you to tune it to your liking. I had no idea my car could handle as well as it does now.
my car is more comfortable w/ the TC Klines than it was stock - no bounce on the highway. It's FIRM but very livable. But those are EXPENSIVE shocks to run every day. The only times my car sees the street is to get gas, and likely next year it'll be un-registered -- it's just not worth it. I have a trailer, tow vehicle, and feel that's the way to go, otherwise you'll limit how much you can do with the car / how much you dare push it, etc...
