burping differential fluid
Old Jan 9, 2008 | 06:52 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
Exclamation burping differential fluid
does anyone have any issues of the diff fluid coming out of the breather tube? i didn't use to have the problem when i had the stock VLSD, but now that i have the cusco, i noticed it after a weekend at buttonwillow. there was maybe one pint of fluid splatted on the left hand undercarriage.
i saw one member a long time ago make some sort of a catch can, but did a search and couldn't find it again. have you guys made anything like that. just trying to get some ideas.
Old Jan 9, 2008 | 09:07 PM
1cockyZ's Avatar
1cockyZ
Maybe you just overfilled it a little. Pull the fill plug and stick your finger in there. The car must be absolutely level.
Old Jan 10, 2008 | 05:14 AM
racerbob4's Avatar
racerbob4
That happens when you race the car hard. When we fill the diff we let the small amount of excess drain down before we install the plug. We use Red Line Oil in our car throughout.
Old Jan 10, 2008 | 07:53 AM
daveh's Avatar
daveh
Yes the differential overflows out of the breather tube under race conditions. There are 2 things you can do to help this.
- Build a simple catch can (I used a small nalgene bottle mounted to the subframe)
- Replace the overflow hose with a hose about 3 times as long as the stock one and loop it around a few times before it reaches the catch can. The long hose catches most of the overflow fluid and allows it to drain back into the diff when it cools down again.
Search under my name for more info on my cheapo homemade solution.
Old Jan 10, 2008 | 09:21 AM
dklau33's Avatar
dklau33
Yup, my car did that when I had my quaife installed and took it to the track. Rob at ZCarGarage just replaced the breahter hose with a really long one so the fluid would just drain back after cooling.
Old Jan 10, 2008 | 10:22 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
i read your thread about a year or two ago, but i couldn't find it again (when i needed it); imagine that i am definitely going to have to get under there and do this catch can. i don't want the fluid all over the track, then people will look at me like this
Old Jan 10, 2008 | 10:23 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
hey dave, i just noticed your sig and saw that you were an instructor for speedventures as well. will you be going out the end of the month?
Old Jan 10, 2008 | 12:33 PM
daveh's Avatar
daveh
I don't make it down to too many SoCal events these days. Come to think of it, I haven't been to a speedventures event in over a year..
Old Jan 10, 2008 | 12:36 PM
daveh's Avatar
daveh
https://my350z.com/forum/showthread....hlight=nalgene
here's the old thread
Old Jan 10, 2008 | 01:36 PM
RKnight's Avatar
RKnight
You should have come out for the Speed Ventures Nissan Festival last month.Cold and windy on Sat. but nice sunny day with a lot of nice cars on Sun..
Old Jan 28, 2008 | 08:22 AM
n1cK!'s Avatar
n1cK!
Infiltrator!
well, i found a pretty good alternative to the catch can. i followed the suggestion of some of you and went with a really long tube. well, it was just two feet, which is twice the length of the original. after tracking yesterday, i checked the undercarriage and it looks like it worked! all i did was wrap it around the subframe once and put it back in the stock locations.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
